I've never been the biggest fan of red. Black is more my style :) A nice shiny black.
Man... I'm getting wood just over that description!!
Hmm... Flared guards... How would that look on mine? I'm going for a similar bodykit to last time but more aggressive rear bar and alternate front.
Get some decent wheels to go with the black.
Silver / Bronze or Black with a Red lip... That's how I like my Black coloured cars
I like chrome lip wheels. Centre can be silver/black/gunmetal, I don't mind.
I want something like TE37s but it's hard finding good offset in an MR2.
7.5 in front and 8.5 rear with +29 offset on both would be exactly flush.
Is this the kind of look you like???
Edited by jezza boii
Fucking love that look!
WORK Meister S1's or SSR Professor S1's, both look great!
On that note, both those wheels look the same. :)
Cuz of the polish lip, you can mix up the colours a bit to get some variety happening.
Any of those center colours would look sic!
The Time Attack TE37's would looks nice, but good luck finding those. Hah!
those wheels will probably cost more than the price of your car :) at least that's what I found with my golf and work meisters.
Yeah, I won't be getting Meisters. I only want to spend about $3000 max on wheels + tires.
So what do you think of the overall look of that car Shan? Coz that's my inspiration for this project.
But unfortunately I won't be pulling 330rwkw like him :( Otherwise I could buy in on this "my dick is bigger than yours" contest between Kris and Hamish :P
grow some
ahahahahah
nah i dont wana mess to much with what mitsubishi already made good
i have seen the 1/4s being wrecked because its flared out, evos in US that have had them done
ill roll the lips though
just pump the whole guard then.... i got nearly 2 inches on my 33 like that :)
(but get athid to do it....)
and no I dont care if kris has more power than me... i actually hope he gets it as he NEEDS it to get away with the paint :(
yeh thats what i mean pumping or flaring its gona look shit on the evo
lipping the 1/4s is all you can really do cause the 1/4s look good as they are
I've never been the biggest fan of red. Black is more my style :( A nice shiny black.
:) okayyy...
haha if it stays too long in one spot it'll cause permanent retinal damage. with 300kw, it'll only be temporary
2x Adjustable Cam gears - $129 from Access Auto
Water pump, timing belt, bearings, seals, fuel filter, thermostat, stud/bolts - from Kudos Motorsports
ASI 52mm dual alumn radiator - $200
Need moar money
Then comes other crap to get water/meth working and then re-tune :)
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
