custom.
do it once do it right.. otherwise ull get some shit u dont reallllllly want and decide nah these suck and u cant sell em cos the fail offset nobody else will want them + u then will have to go get the wheels u wanted in the first place.
diamond racing steelies are awesome for oldschool cars...
http://www.honda-tech.com/attachment.php?a...mp;d=1234747508
cheap, easy to get in any offset, and looks good on a car from the 90's. That white one is pure porn. Jizz boi, those fitments are fagworthy. try harder.
I'd go 7.5" +18 up front and 9.5" +18 in the back minimum. MINIMUM. don't be a limp dick.
Diamond Racing can custom make you steelies up to 18" diameter and 28" wide in any offset. They can also polish the outer half or you can just get the whole thing powder coated. For you guys in KE's I'd totally be jumpin on it. All the poor kids in the US seem to be rocking it, it's only a matter of time before guys with a little more money jump on it and whore the style.
Because I can not find any in that offset anywhere!
All I find is stupid 10" wide shit made for GTRs and Evos... I want staggered.
Jezz, you spoken to Streeter yet?
If not, get on it. He'll help you find the right wheels on yahoo auctions.
Yeah, either Streeter or Aaron from Import Monster.
how much we talkin? i'd rock that shit
I looked at the Import Monster website and it seemed a bit too pricey for me.
$1500 - $3000 is my budget including tyres.
Anyway, I've gotta go people... Time to go get my head kicked in :cool: This will be fun...
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
