pretty much exactly what my 32 GTR would look like if I bought one...minus the paint on the tires.
Hrm usually im against that kinda stuff as well but that actually isn't all that bad - im quite impressed with it.
It works nicely with the wheel colour and immac bodywork
that's too good looking to be your car. issit?
edit: wait, that smells like a GTR.
tsk tsk Shan losing your edge :)
Should have been able to point out the gtr skirts! They cant fit on gtst's due to the flared rear guards :thumbsup:
The white writing looks pretty neat though.
its a bolt in cusco cage, so it's possible.
also GTR side skirts fits fine on my 32 GTS4, altho I am running GTR fenders and flared rear guards... hmm didn't even think about that.
yeah i dont mind the tyre text
anyone wheel shopping atm should keep an eye out for these:
http://varrstoen.com/blog/
hot shit, predicted.
they'll ship to oz too :thumbsup: and they make a great CE28N style wheel.
has anyone noticed when you go through school zones where you have to do 40km/h its always the parents with little kids go flying past you when they are the ones that wanted those speed limits, that really pisses me off, i dont have kids but stick to it so why cant they?
cos once their kids are sefely in their SUV's, they don't give a f**k about anyone else.
that is right, its always the ones in their suv's that speed through these zones and tailgate And dont get me started on those people in those bmw x5's :)
the parents have to get to the gym and coffee, thats why they drive the big SUV's so when they do hit a kid theres minimal damage to the car.
my super awesome original spec 60gb playstation 3 failed.. yellow light of death.
spend $200 and fix it with a big chance of it failing again or buy a 250gb slim version for 550 or save the coin
hmmmm
Edited by GTR-boy
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
