I think it is nick. As far as I know front and rear were resprayed due to accident. Never had a full respray
yeh, had a full respray a few years back to slightly different colour...
quick question to anyone that can help I need to know fast how much should I be paying for some half decent tyres for my GTR? 18x10" 265s on all 4 currently have some bridgestones on but need new ones or can anyone recommend something decent value for money? car is street / track day once every 3 months.
thanks in advanced
lol @ KU36 semi slicks on a daily driver. Hope you enjoy changing tyres every 3 months.
FWIW I get 265/35/18 KU36's for $240 a pop.
I'd recommend a KU31 for dailies or a KU17 for best bang for buck.
Also I get Federal 265/35/18 595-RSR's for $350 each
Kumho are reasonably good quality as a tyre (better than the other 3 i still have on! ) but id get something in a Toyo if you can...last forever :( and grip well enough. I cant say what their performance tyres are like, the only set ive had were on the N16... 185s! lol. but they were a comfy ride :P
Kumho's I think are a best all-rounder and they cater for all types of driving and a lot of ppl I see recommend it.
Toyo's are top of the range as my mechanic thinks.
Bridgestone's / Yokohama's all do a good job, but you would pay a bit.
I had Yokohama Advans, nice tyre but were harder compared to my Kumho's.
Pretty sure thats my 'odd one out' (my only half decent tyre)
Ecsta SPT KU31...does a good job. Just have to replace the other 3 cheap Fullrun compliance tyres lol
i was not recommending them. my point was that he should shop around.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
