Pretty sure thats my 'odd one out' (my only half decent tyre)
Ecsta SPT KU31...does a good job. Just have to replace the other 3 cheap Fullrun compliance tyres lol
please tell me you're not running the odd tyre on the front passenger wheel on a GTR.
Front driver side. Given that one of the tyres I HAD pretty much popped just before i hit eastlink a few months ago...i kinda had to replace the piece of shit. make matters worse the stupid japanese battery then died and i had to pay almost 200 for the only battery that would fit...and a further 10 to change the terminals to fit... it ended up being almost 500 on just a tyre and a battery in the week where i didnt get paid. so...bite me for having to do what i had to to get the car going again rather than replacing all four :(:P
what type of battery? bit steep for a normal one
i just got quoted $300 for an optima one (has like gel inside istead of water and gives heaps of cca)
its sort of longer and flatter rather than taller. Its called a FullRiver? meant to be really good for running excessive car audio and shit. was about 180. needed something that could fit in the battery cavity...especially given we had no tools at all to take the rear strut brace off...
lol way to overreact. as long as it's not the passenger one, it's where the anti slip sensor is most sensitive and usually something like a good tyre on that compared to three shagged tyres will make your GTR constantly think you're doing epic skids.
part of the reason we opted to have it towed rather than try the epically shit spare they give you. for one its based off of the 17" stockies, the car is currently running 18x9.5...so the spare was smaller. didnt wanna chance it. had total cover with RACV at the time as well, luckily :( free towing ftw!
What's happening tonight?
Is it just me... or does it seem like everyone drives like a dickhead on fridays? I had 2 commodores and a 7 series beamer muck around (on the freeway no less) while I was driving >.<
shan i will hit you up when i need tyres, it seems because my car had been sitting for probably about a year + not doing anything in japan there is some small cracks in the tyres.. traction tyres suggested to get it replaced ASAP but kinda thinking they just want me to spend more money there.. as they are really only small cracks I might take some pics.
Anyways cheers all for the info :mad:
EDIT:
BC COILOVERS FTMFW, sooo much less bumpy then my brutal teins were, they feel sooo much better for a daily driver and no knock ftw.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
