i like buying expensive clothes. that probably makes me a phag. but i still love this shit:
apparently she was at some bar with ruby rose last week.. my matesthat managed to get in saw her but i couldnt get in lol
after his glowing appraisal, i'm expected to buy it off him? lol
still no idea what to do
depends on what you want...
i prefer my boost to spike a little at the start to get things happening, which is why i have the gain set to max. trent has added the timing progressively to keep it safer
and in all seriousness... i dont mind it trailing off near the limiter with 300rwkw on stock internals
sell him your spec "s" kris...
I run one and find it is perfect for my needs.
It spikes to 20psi and then trails off to like 18.5 by 7400 with the gain set to full :laugh:
He could if it was still his...failed to mention that he'd already sold it to me :domokun:
Spec S is perfect for running 14 psi on the GTR :(
pwnd hard. thought you road rego'd track day car was stealth?
twas. All he could get me for was my bleed valve. Which was covered in duct tape and shoved under the intercooler piping. It got slightly moved when the power steering lines were customized. Cop had his massive flashlight and was viewing the turbo from every angle to find it.
His only mission was to find a boost controller and was set on finding one...
4yrs of daily driving in Knox/Rowville, it was only time until an epa showed up
After all of this, will just run an adjustable actuator and prob get one of those legal exhausts from racepace.
Then they can go and get f**ked.
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
