Yo yo, I havn't adjusted it at all cost me like 300 all up with a wheel alignment and height adjustment to lowest legal, they setup the stiffness on what you say I told them I will be using it mainly for street and a bit of track work so they did so quite well I think (traction tyres in rowville) so couldn't answer your question apart from recommending to get someone else to do it, because they gave me a sheet with camber % and all these different readings which I had NFI about, and even if I did how the hell would one get into that much detail in there own garage with a jack.
fair enough,im getting mine done on thursday along with a full service, belts and everything so im looking forward to getting that done and knowing my car will be very healthy.
what's the industry term for the printing on the NS hoodies? don't think it's screen printing, it's more like a heat transfer style...
I need to find a place that can do it..
silk screening?
thermal transfer?
Goto one of those "T-Shirt" bar places and they could transfer the image on for you...
silk screening?
thermal transfer?
I'm thinking it's thermal/heat transfer style, but the singlets I've got from last years pre season just have this certain feel about them (where the printing is)....I'll have to take that to a few places as a sample and hope they can match it
Not exactly on the scene with my current vehicle
need to man up and get a gtr then :D
reporting for duty.
and u aint no gtst sedan stop false advertising
haha i used to be cool :blink:
now i just drive a yellow lancer
i hope so - was a very rough start / idle too
first time its ever done it
noticed when I turned the headlights on i could hear a bit of a whining from the engine same when i pushed brake in a tiny bit :S :D
which i have never heard before also
Lol Leigh you stooge. I'll install a head unit for you. It's a piece of piss. Already did 3x r33, 2x r34, alfies celica and prob more lol
lol i know how to do it just needed the wiring diagram :huh:
had the head unit in my closet for a month so i figure ill put it in and do some cheap speakers at the same time, cbf with a good sound system anymore i only use it every now and then for a few tunes and dont tend to crank it
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
