just picked up my car from its full service and its running soooooo good it made me jizz in my pants. the reason why it wasnt running well and wouldnt start properly was that it had the wrong sparkplugs in it so thats all fixed now and the boost sensor works again too, it was a hose that was disconected. im wrapped >_<
7am wake up killed me
but my manipulation massage was awesome :D
Sook. I get up at 5.30 every morning (except weekends), although this is the first saturday I've had off for a few weeks.
By manipulation massage, you mean a hand shandy? >_<
Morning sex before work is the ultimate I reckon.
Hey Paul, I'm looking at buying this power fc:
http://www.skylinesaustralia.com/forums/Rb...ts-t331802.html
But the guy says its a pro version but after reading through your site (awesome site btw), the sticker means nothing and only other way is to open it up or get his word for it for the launch control etc, your thoughts? is there any way you can check the serial number or something?
He said he could do 950 because its a 'pro' version
By manipulation massage, you mean a hand shandy? :)
nah mean my back was fucked and got it fixed
lol if the massure was a hot chick then yeh hand shandy would be good, but was a dude :woot:
yep it's just a normal powerfc to suit RB26
the Fc pro sticker just means you can connect it to apexi's power excel fc commander sofware (who really cares?)
the only way he can prove it is a legit pro version is for him to get a photo of etc, VERSION and get him to show you the photo
there is nothing stopping him looking on google to find a pro ETC, VERSION photo so you would never know and could never confirm
Thanks for the reply Paul yeh I thought so as well the guy said that he never had it on car but the guy he bought it from said it was a pro.. but I doubt it.. pretty sure itll just be a normal one.
As for series 3 midnight purple good luck I looked for ages! I saw that one come up on carsales after I got mine but the thing that got me was that it was a 96 with xenons which as far as i know (correct me if im wrong) 97 and 98s came out with them only? so maybe a accident or something? :s
I always thought:
95 GTR series 1
96 GTR series 2
97-98 GTR series 3
I'm glad I got a 06/98 built 33 :)
Lol at dropping Parker globe in headlight. After using a magnetic rod and not being able to get it out I just tookthe whole headlight off
lol same
bendy straw + chewing gum did the trick for me when fishing for dropped bulbs. I got all McGuyver on that ass.
nice
why dont you tie some thin fishing line around it? so it if falls you just pull it out gently, when its in, poke a knife in the n nip the line. done
no
I just left the parker globe in the headlight..
lol
    • Hmm. I should have thought of the clutch bleeding issue. It should be #1 thought for "can't select gears". As to "sounds like the top".....have you actually gone out with the stethoscope and tried to pin it down any more than that? And, buy or borrow a timing light, and set the timing properly.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
