haha nah, thats the only pic i had of it, took the numberplate out incase i was pulled over :ermm:
you can see the bottom of the rearbar took a lot of the flame action to it, cause the sedans are a tad longer and i was running a coupe catback it went straight into the corner :P
haha nah, thats the only pic i had of it, took the numberplate out incase i was pulled over :verymad:
you can see the bottom of the rearbar took a lot of the flame action to it, cause the sedans are a tad longer and i was running a coupe catback it went straight into the corner :happy:
it took a good flame that rear bar. i was wondering how the flames got to the numberplate lol.
how long did you run your car like that before you decided thats enough?
A few SAU members have a LM Edition.
Besides the colour (Champion Blue) it is just like any other R33 GTR from factory, nothing huge to separate it from the rest to make it special...
The R33 GTR V-Spec didn't have a huge impact, just an Active LSD and a newer ATTESA E-TS Pro all wheel drive system, lower ground clearance in resulting the car weighing 10kg more.
Like the R32 GTR Nismo Editions = Stock GTR with a factory Nismo Bodykit.
The Nismo Bodykit could be bought for base / V-Spec / V-Spec II / N1 models.
V-Spec / V-Spec II's were not much of a big deal but only for the Brembo brakes and 17" BBS wheels.
The price you pay for a V-Spec / V-Spec II / Nismo Edition, you could probably buy the base model and add the Brembo Calipers, Nismo Bodykit and a set of 17" wheels of your liking and still have cash left over...
With the R34 GTR, the big changes came when the N1 was released then the V-Spec II Nur.
The GTR N1's / Nismo 400R / V-Spec II Nur, were the ones with a decent upgrade from factory to separate them from itself.
umm im not sure what the place is called :happy: but i know exactly where it is and been their a few times (its in mailing road near all these antique and 'posh' shops >,<
nah i dont know the original lolly store :happy:
lol
*this thread is now about candy!
:verymad:
Haha!
I will do a little reseach and see if I find anything in Surrey Hills.
Cool!
For anyone interested in quick wiring. Used one of these for wiring up my thermofan controller. Has a LED on the fuse too, so if it blows you can see. Quick easy way of wiring up power etc without splicing etc.
http://jaycar.com.au/productView.asp?ID=SF...mp;form=KEYWORD
you paid 7 bucks for a $0.50 fuse with light that has a wire soldered onto it?
man I need to start selling this shit on ebay.
haha i paid for the convinience. The led and wire are soldered into the plastic housing not on the prongs ontop of the fuse + the bullet connector.
yeah fuses are 10c a pop, 20c from dickies or repco if you're in a jam. 50c gets you the one with the lights built in.... $1 at the most.
blade fuse (with no led) - $1.00
bullet connector - $3.50
Throw in the wire, rubber cover, led and crimping/soldering the whole lot for extra $3.00
(jaycar prices)
:verymad:
or $7.00 for it all assembled and save myself 15-30mins?
Make me up another one for under $7.00 and ill buy it. Better for me.
yeah I suppose if you're buying electronics retail then it works out. lol it's kinda like if I was to go pay retail price for chocolates, you'd be like "lol n00b"
yeah, started watching the one about old people and then saw that the new episode of Psych had finished downloading so I watched that instead.
its one of my favourite shows. i got all 8 seasons so far. still downloading a few episodes from season 8 actually, my internet connection has slowed down atm so its taking forever :verymad:
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
