fucking hell.
EPA full emission and noise letter came in the fkn mail. Due Date 8th September. Sucks arse
The world seems to balance it self out, on one hand im flying business class to Ireland/Germany/Poland for work and then this EPA bullshit is due whilst im overseas.
If fail EPA test, retest fee is $39.40. No mention of fine if fail, so I guess thats okay :P
Going to write a letter and see what my options are... FML
Try to do everything by the book and an arrogant pig has to fuck it all up with a bleed valve. /Ragequit
dunno if i wanna go for this look. but possibly
18 inch Work Meister S1. Epic dish. $3300
They are 18 x 9.5" +16 and 18 x 11" +16 with 5 x 114.3 stud pattern
lol that's the sizes that's goin on my golf. meisters. with even more offset. deal w/ it.
also, if you're gonna rock epic 3pc meisters with chronic offsets, and your rim's not gonna sit less than 1cm from the fender, don't buy it. let it go to a good home instead.
it's like abandoning a puppy when it grows up cos it ain't cute anymore. furreals.
been gone 2 months and your still getting your rims, whats the go?
gettin outer barrels made. i told em it wasn't a high priority job... no rush. it doesn't need to go on till car's resprayed and panel beaten anyways.
plus the bolts haven't arrived from germany... this is due to waiting on my not so clever cousin to mail it to me.
altho now that I'm public transporting it like a peasant I might as well get it done.
LOL If your referring to me, you either hadnt seen my car with previous wheels or you dont know how I roll LOL
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
