Yeah still there unfortunately....Another 4-5 months and I should be gone though....Start my sparky pre-app on Monday :yes:
Got offered a contract at Schweppes but knocked it back, pre-app is full time so I'll need to be doin a few night shifts for the next 4 months, then hopefully gone forever!
P.S Still dying.
Awesome man! Where are you doing your pre-app? When your done the pre-app and looking for work, let me know I'll see if work will take another apprentice on, but we just took a new apprentice on so it's not promising.
370 degrees/victec..
One of my mates is pretty sure he can hook me up when I'm done so I should be ok, but I'll keep your offer in mind as well :thanks:
I did mine there. Wasn't too bad, yet that was 8 years ago :down: Might have changed a fair bit since then.
What sort of work does your mate do?
Maybe someone in the wastelands will know this.
Before my diff died i realised that the car was driving much slower, as in getting bull boost by 5000Rpm :s felt a lot slower. so question is, if your diff is still working, (as in car moving) can a f**ked diff have a power loss at the wheels?
I did mine there. Wasn't too bad, yet that was 8 years ago :) Might have changed a fair bit since then.
He's a 3rd year working through 370....he's injured at the moment though so not working
Ahh so you mean you'd work for Victec? (Or whatever they're called now?) lol. I did my apprenticeship with them too, but was kept on the entire time by the same company.
Had to work today too, looks like I'll be doing a 20-odd day stint without a day off :)
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
