still at that same smoke place or whatever?
yeah come out
lol yeah still working for philip morris...
over 6 years now... cant see myself ever leaving, they treat me too well :P
when he f*ks off to buenos aries for a couple of weeks i'll come on and we'll organise a cruise or something.
haha nice
over 6 years now... cant see myself ever leaving, they treat me too well :D
haha
i remember when me and kris came over that night and you thought we wernt there.... kent :P
K results from my 2-way diff are here. Every single gear has been rounded, caused by poor assembly. f**k you up the ass creatd ya useless f**king maco's
didn't you buy that diff 2nd hand kris?
also creatd dont do diff work, they send it off to a diff shop that they will most probably give you the details for
If they dont do the work they shouldnt have taken the diff. It was second hand but there was nothing wrong with it. When the guy opened it today he saw straight away that shit wasnt right. Might be a good thing, im over the 2 ways now, want a 1.5 way.
Mah nigga, how the defect go? still cruising on my awesome stockies?
mah man!!!
nah bro the car is at matts still since i cant drive it.... i have to get it cleared before they de-rego it.. havnt seen my car since i picked up the stockies
we have to have the old school meets.. like back in the day
yeah creatd don't bust apart diffs.
also how do you assemble a diff wrong if you give em a housing and an assembled 2 way? There's only one way you can assemble it, everything either fits or it doesn't.
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
