according to work usa, the 9's are Odisk @ 96mm, the 9.5's are Adisk @ 83mm. curious enough to search lol
uhhh ALL works wheels come in A, B,C or O centre. You choose the centre based on the brakes you're running and what kind of concave etc you want.
just get whoever's buyin you the wheels or gettin em from to measure the lip for you if all you wanna know is how much dish you'll have. You can't tell that just by using the offset and width.
yes yes i knew that disk affects dish - just didnt know which was which, and i dont really care exactly how many mm of dish i will get. just bored and decided to learn something. now what i dont know is whether o disk will clear gtst brakes.
also it seems i'v broken my right hand shift button on the keyboard
FML, So as a condition of roadworthy I had to get my drivers side window working (previous owner disconnected as it wound itself up) So I took it to the auto-elec today and they rang me during the day to come get it........ FARK final cost= $360.46 wtf? just to fix my window are you serious????? :D
That's my gripe for the day :)
I was a year and a bit...
That's a fair while. I thought I was bad @ 6 months late.
If I got my license at 18 I would be getting my fulls in 4 days :) Unfortunately I've gotta wait til next year.
If I got my license at 18 I would be getting my fulls in 4 days :D Unfortunately I've gotta wait til next year.
LOLnoob....L2getlicensethedayyoucan.
I got my Ls the day I turned 16 and Ps the day I turned 17. I was even late to my PD/H/PE HSC exam because of it :)
At the time I was living out in the sticks. There was no friggin' way I was going to wait a single day longer than I had to to get my license.
At the age of 18 I had no interest in driving. I could walk/skate to school and friend's houses. I didn't even like cars at that stage.
When I started working I realised that I needed to drive. Did 15 hours on my L's and then fluked my P's test.
Once I started looking to buy a car I realised how awesome they were :)
had my L's at 16, P's on the day I turned 17, lost it by the age of 19. Full license at 21.
I'd have had my full by 19 if I hadn't lost it, but cos I lost it I went into the 3 year P-plate system instead of the 1 year P-plate. FFFUUU.
So you on full license now...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
