ended up ordering 10 large pizzas lmao
on another note
my luck gets worse and worse with skylines
every f**kin car i see, am bet to it by a small amount of time
all the replies are "just sold it man" and "sold it yesterday"
f**k!
Im assuming your after a non-turbo model right?
Try interstate also, a $100 plane ride might find you the right car
on another note
f**k!
wait... wut? wtf is wrong with you, ngas are mad desperate to get rid of their skylines and you can't find any? put up a wtb and watch your inbox flood.
are you trying to find cheap shitheaps? you've been asking about cars blowing blue smoke etc. of late.
Dont get your hopes up, in the prologue the cars handle like boats in the real game should be a lot better though.
and GTR-BOY i sold my n/a 33 125rwkw yo. for 9500 you coulda bought it! :)
chicago is a dump. all the places those risky devils guys film at are abandoned industrials where the only people there are hobos. and there's a LOT of abandoned industrials in chicago.
modding rules are fairly lax, although it varies from state to state. plus it's a big place, so to put it in context ... some places in the US are like owning a modded car in country VIC, no copper's gonna give a shit if your car's illegally modded, they usually have bigger fish to fry.
http://vimeo.com/14741098
dude in canada at a drift comp. R32 in front of him spins out, he can't stop, but spots a gap between the wall and the spinning 32. shoots for the gap, but the 32's back wedges him, flipping him over.
he gets the car flipped back up, then proceeds to drive back to the starting line to do another run (with crushed roof and rear), which he almost pulls off, but a front upper arm gets wedged into the chassis cos it's bent, making him unable to steer properly so he taps the wall and gets knocked out of the elimination.
now this guy has balls.
billy- yeah, i think i might have to go interstate. im leaning towards an r32 taxi
shan- found an R32 sedan, was all good but blowing blue smoke
i can be a bit patient, still working and putting money away. boats going up for sale, so is my other junk so i should( hopefully) have a bit more coin to play with.
are their rules more relaxed than here or do the yanks just have bigger balls than aussies when it comes to modding street cars?
yeh for the most part fairly lax most states height rule is bumper cannot be below the bottom of front rim .. which to give you an idea is farken low.
but like funky said heaps bigger fish to fry when you got kents with guns wandering around... but they hammer in some states i think cali crushes hoon cars regularly and they hand out lots of fines etc..
risky devils are gangster haha.. ill get link to extended vid its even betterrrr
lol one of the risky devils guy is a complete fuck-knuckle tho. Drives a red IS. Most of em are members on ZT, they're cool duders, but this guy just pisses everyone off.
you can't play online with it... you'll get bannzor'd. it's the USB dongle... I got the opensource DIY one and I'm building it myself. To un-mod it, you just pull the dongle out.
Finished DL'in Mafia II last night... gonna have to try it once I flash my dongle.
Hmmm so lets say u want to use the mod, disconnect the ps3 from internet, play burnt game.
Then i want to play cod online so i would just, remove the mod usb thingo, connect internet, then play cod?
Or does it leave certain files behind that can be found out by sony?
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
