shit, i'll even throw in a half shattered bodykit that makes the car sit 2cm off the ground. I've reverted it to factory plastic so I can be all like "low stance, no care".
What brides you got Alex? Pics now :D
My Recaros are getting retrimmed in the next few days. My motor trimmer talked me into doing something totally different. You guys probably won't approve but oh well :D
around that age i rkn they'd all be the same i dont recall any widescreen single din head units luls..
tried autobarns an shit? they have heaps of those pockets..
haven't yet... i was hoping for a genuine nissan one but i may have to go crappy aftermarket type.
the only one i could find easily was from a 2007 x-trail... not sure if the fittings and shit are the same..
what seat did you get mang? EDIT: beat me to it jizzy.
chasing one with a door (to hide firearms and *gasp* EBC) but they are harder to find than osama :D
you want a ceffy popout drawer, fits in any R31-R34 skyline DIN. full DIN size drawer that clicks in to lock and clicks in to slide out using a spring load. gangster as. good for hiding rubbers/ipods and shit which you want easy access to but don't want visible all the time.
try wreckers. Think Laurels, Cedrics, Cimas and Glorias also got em.
and no you can't have mine. unless you buy the car.
Retrimmed ey... what gayness could you possibly bring to us now? crocodile skin? snake skin? something gayyer?
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
