Would be hilarious to see an Arab / Asian / Jew / Indian to do business with each other... :(
THAT WOULD BE THE WORST COMBO!!!
Indian - too cheap to invest
Arab - smart enough to scam
Asian - wouldnt give you a bargain
Jew - well not sure what they known for.
ive dealt with jews, indians and asians
for me, arabs are the worst by far( they think just because we speak the same language im gona get on my knees and blow them while giving them a 60% discount)
indians- you get your cheap ones that want something for nothing and you get the ones that will actually spend some coin and get something good.
asians: not bad, complain alot sometimes
jews- all good, they come to buy, not to look and bust my balls and then buy lol
^^ This.
But you come across the good ones of all kinds so it not too bad.
My mate said the same thing about us....he said he has been proven wrong that all indians are cheap and never want to spend money...i replied and said which indian you know has spend some decent money around you...he looks at me and cracks up laughing...i didnt get it until he replied...YOU!!!
man living here i dont consider myself as a typical indian...weird... :(
Yeah, you ain't that cheap...
But I still won't give you a good price.
TYPICAL ASIAN!!! :)
but hey they are better friends than indians man...i have asain/arab/wogs/aussies friends but indian ones i have are the worst in the list...
indians- you get your cheap ones that want something for nothing and you get the lankans that will actually spend some coin and get something good.
fixed for accuracy :(
Mind you lankans want top dollar for everything they sell, and convince you somehow that it's the right thing to do.
TYPICAL ASIAN!!! :(
It good price for you... You buy now!
Most ppl I hang out with are white and some have Asian / Indian blood in them.
A friend of mine looks white but is 1/4 Indian.
Same with my other friend who is 1/4 Philipino, but looks white.
True..some lankans i know spend like no tommorrow and always buy the best stuff...they are good people in general too...some though ruin the reputation of others...hate when that happens...
its good to want to strive for the best.
my friends asked me why i havnt "choppd da springs n slammed it"
i said: cz i want to do it properly
they just look at you funny thinking wtf
then they move on to the rims.. "cuzz lets go to de tyre faktry in thomo, all de thomo hoons go there i cn hook u up bro"
me: nah, im allright.
HAHAHA!!! sounds like i have been in that exact situation... :(
would be so much spit flying round that convo
indians- you get your cheap ones that want something for nothing and you get the Singhalese that will actually spend some coin and get something good.
re-fixed. Tamils are dodgy as f**k. Just sayin.
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
