f**king tyrejoints are shit. 3 didnt know what hub rings are, 2 say that they dont do em, 1 told me i dont need em. f**kers
bahahaha now what did himish tell you? :P
go to the wreckers
tyre joints shouldnt stock them, ive been to tyre joints before and they dont stock them unfortunatly
some do... some dont...
even I think that is a sweeping generalisation
Ham, nice motor.
iPhone is finally unlocked at the comfort of my desk - thanks Nick aka WGNPWR for his help.
Just bought myself a pair of nismo AFMs, injectors. Now, I'm umm-ahhing about turbo upgrade twins or single is the question...
I could be wrong here ... and probably am. But doesnt it stop oily air being plumbed back into the intake?
which should stop oily buildup in your intake pipes
yeah pretty much, removes oil in air lines.
wtf u doing man. I told you several pages ago. Email http://www.speedywheels.com.au/ and tell them your diametre of the hole in the centre of wheel and the diametre of the axle hub. They then will send you 4 plastic rings for $10~ and it will be in your fkn mail box the next day
Shan, stop confusing everyone with your leetness. Simple solution, if you got second hand aftermarket rims, get some hub-locating rings if there is a gap.
Hub Location - Alloy Wheels
The hub hole is the hole in the centre of the wheel which mates with the centre hub of the car.
By not locating a wheel on the cars’ centre bore, the vehicle can sometimes encounter vibration problems.
All Speedy alloy wheels are either supplied with centre bore locating rings or are machined to be a perfect fit with the vehicles hub to completely eliminate any of the above mentioned scenarios.
remove your AFM, stick hand down intake pipe. Remove hand to see coated in oil. Thats what the catchcan tries to catch before it goes through your turbo, intercooler and engine.
*facepalm* look at the diagram that you just posted and the diagrams I posted above and figure out what type of wheel Speedy is referring to.
whatever, just do what you want.
oh noes, oil in the engine!
wtf you on about? the majority of any aftermarket rims arent lug centric and will require hub locating rings. The best they will do is have the diametre the same as the axle hub (for example LMGT4's are direct fit onto the axle hub)
and oil in engine is referring to having an oily air intake...
lol actually most aftermarket rims are lug centric and not hub centric so that one wheel can be used on multiple brands of cars with the same PCD but differing hub centre diameters. Some may use hub rings for reinforcement if they have say not enough material around the lugs to take the stress, but no manufacturer is retarded enough to make a non hubcentric AND non lug centric wheel.
NISMO LMGT4's are hub centric because they're commissioned by Nissan from Rays FOR NISSANS ONLY.
just cause it can be used between multiple brands of cars doesnt mean they have put the effort to make them a lug centric design. Speedy Wheels for example proves that. Lets say that even if the rim is lug centric design, i believe there will be no damage caused when using hub locating rings. After all, the rings just position the wheel into the centre of the hub. If you then screwed in the wheel nuts, they will go directly in and not push the wheel into the centre as it is already there. Therefore the nuts will serve their purpose of holding the wheel in place...
Hence for anyone who is unsure, hub locating rings will just make fitting of the wheels easier even if you have a lug centric wheel..
yes i know they made for nissan, why else would i say thats the best ive seen for an aftermarket fitment...
bahahaha now what did himish tell you? :thumbsup:
umm i forget. what?
i'll let you ppl figure this hub thing out for me. in the meantime, the centercaps on my wheels are held on by 8 allen bolts. which also happen to be slightly seized. ergo - wheels cant be balanced. fuuuuuuuu. wd40 has been applied, will attempt removal again tomorrow.
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe will give me my power goals and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
