not even, its illegal to sell the car with an EPA notice on it lawl
haha pwnd hard. i still find it hilaaaarious that none of the boys sporting skittles coloured fibreglass speedboats and big fuck off shiny mods never get done so hard, yet you, mr under the radar with tasteful mods for super hektic trackdays only gets shafted.
I live in Knox and use it as a daily hence the pwnage lol
bahahaha now what did himish tell you? :P
umm i forget. what?
do a ring around first, as many places have no f**king idea what they are, it took me 3 visits to get them from bj's
thanks hamish
noob question
if my guards need lipping(i looked under the rears, lips about 2cm in) could i get them folded IN, instead of having them out?
also noticed ill have to take out the inner front guard if i want to slam it..
learrrrrrninnnggggggggg
Nah, been the last two years in a row. Can't afford to go again next year.
Do you have any recommendations to make while I'm in Tokyo? I want to check out as much jap car stuff as possible, drifting etc. Let me know your thoughts!
thanks hamish
noob question
Ok so getting that bit folded up is also know as getting your guards rolled. Ask hamish who he recommends to all you easties, costs about 50-70 per corner. And yes, if you go low you will need to remove the inner plastic guard.
o i c ty
athid...
seen you recommend him in a few threads.
now to work some more and buy rimsssssssssss
22"chromies?
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
