fkn barbs
yet another reason to hate barbs...
It's perfectly safe. Every mechanic has told me that. They couldn't even tell that the chassis was bent. It was the old owner that told me that.
dood... that's a fkn dog act.... i'd headin over with a baseball bat
my commodores chassi is bent and you cant tell if it is...car runs pretty straight....lol...
of course you cant tell it's a commo. it probably came out of the factory bent and you crashed and straightened it
:D 1st gutter = straighten it up but the 2nd gutter = bending it more than usual... :) ..been through 2 diffs in that car...give it the beatn of its life time...always shift after four thousand revs... :) (redlines starts just after 5)
friday.is.goods
AGREE!!! DAY TO TAKE MY GTR OUT!!!!
:) sadly the weather doesnt look good for a good nit cruise...
if it doesn't crab and can be negated with suspension alignment, then it's fine to drive. did the owner tell you what else he hulk smashed when he bent the chassis?
If you are gonna fix the bent chassis it's a big job. I'd recommend a ditch and run if it's bad enough that you have to.
if you've munted a car enough to bend the chassis, then the only thing the control arms etc are gonna be good for is as a door stop. You kinda have to replace em, he wasn't doing any favours.
maybe get adjustable arms, makes it easier to offset any misalignments in the chassis compared to static factory replacements.
He said he replaced everything on the left/rear. Tie rod, control arms, etc.
sounds like the result of some epic snap oversteer.
Yeah he was drifting in the wet lol. Who the hell drifts an MR2?!
Where do I get adjustable arms?
I just my car up for sale so want to find out this shit asap lol.
Edited by jezza boii
ok relax, do the following in this order:
1. find out if the alignment can be accounted for using your existing suspension
2. if not find out how much it needs to be adjusted by and what aftermarket arms can give you this amount of adjustment
3. if yes, buy aftermarket arms, fit, drive, enjoy
4. if no, sell car
ok? don't try and do everything all at once. work through the problem.
well you, and the previous owner have both driven this car with the problem just fine so far, so driving it a bit longer just the way it is isn't gonna hurt. it may wear out your tyres unevenly and make it slighly unpredictable to steer on the limit, but it shouldn't matter if you're driving normally.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
