im not sure i agreed? i spent 2k on mine and ive used it every day since ive had the car, so ive had mine for 7 years and the stereo still goes good. some people really enjoy their music and it sounds reasonable to me if thats what he wants, he can reuse it later etc ?
i want one of those navara all in one units in my car, but its got an alpine head unit and speakers all round. so i guess ill put that 600 bux into something else.. like rimmmmmmmsssss :D
Meh all I got now is a pioneer headunit. Took out my 2 x 12 inch kickers and amp ages ago. They just gathering dust ATM
dam...i wud have bought them off you...lol...just bought 2x12 pioneer subs with amp off a guy...lol...cant wait to instal in my gtr...yay finally i can enjoy music in that car too...lol..
I have accrued my $4k system over the past few cars I've owned. It's nothing spectacular. Most of that money is in the $2.5k GPS/DVD headunit, which I got for really cheap after having 2 cheaper units which failed.
I spend a lot of time driving each week. I would go insane without good music :D I am a musician afterall. My life revolves around music. Cars will always come second.
Edited by jezza boii
projector is mounted and all is good
hasnt fallen down haha
one of those cheap $25 ebay china projector ceiling mounts
some of the finish was pretty ordinary, thread not straight etc
i cant imagine a china plenum etc copy where its critical to be clean, straight etc
Man this is getting wierd.
I live on a 16th floor apartment on St Kilda Rd, and in the past two days I have spotted two tiny skinks.
I hope they didn't migrate in my luggage coming back from Perth. Maybe I should check :D
make a terrarium and adopt em
A what?
The missus will freak out if she finds the second one :D
My only thoughts is they climbed up the outside wall and got in through the ceiling cavity (bathroom fan vents air outside to the balcony)
their going to tie you up, rape you and then rob you.
their crafty little f**kers
anyway
i think im in trouble.. girl im seeing wants to go formal with me but i commited to my mates that pre drinks, no bitches, limmo
so i told her i cant go with her lol
anyway
you fkn idiot...
Do you ever want even the opportunity to get laid?
i'm all for bros before hoes, but if you're seeing her, and if it's just drinks with your mates, then you should be making an exception. you can have drinks with them whenever, you can only go to a formal with her once.... unless she or you are retarded enough to repeat the grade. which is totally possible.
in other news, bought some factory Xenons for the golf from japan.
secondhand price from US/UK/Europe: $1500 - $2000 due to VW modders' version of takumi tax
secondhand price from JP: $500 shipped :blush:
love it, these muppets on VW forums are sooo wrapped up in their little ebay and forum world they just don't seem to think outside the square.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
