you should own a regular car before you take on the headaches of a classic.
put it this way, this car's gonna be driven hard once a week. if it breaks it'll go into a workshop while I drive a daily. you, on the other hand don't have that luxury.
i got my parents cars in case something breaks..
anyway, off to sus out my spark plugs and coils again
dude its not hard to suss out what the problem is. Start the car, let it idle. Go to your coilpacks. Unplug the coilpack connector. Change of sound? If not plug back in, and continue through the 6. If there is no change of sound then that coilpack is farked. Replace it, end.
If it doesnt turn out to be the coilpacks, then look towards the injectors. See if any of the plugs has come loose. If it aint the injectors or sparkplugs, it could be the ignition module (the black thing ontop of the cover you remove at back of engine)
the only difference between when you got the car and it running like ass was your brilliant stroke of genius to "reset the ECU". what did you do to reset the ECU?
do NOT do the "tape the coilpacks mod"
i did that, car drove fine for a day or 2 then whenever i put my foot down hard car went nowhere...literally
took out coilpacks and the tape had melted loose and was all over the place
stupidity on my behalf but meh live and learn.
resetting ecu (disconnecting negative terminal for a day) is fine, ive done it heaps of times with no probs.
are you sure you havent unplugged anything and forgotten about it? or any loose clamps etc?
go over your engine bay and check all hoses/plugs etc carefully
just my 1.98cents
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
