most S14's do nothing for me, but I spotted one one the way to school a few weeks back that looked sick...had gay plates 'DAGURU' but the car itself looked the goods...still not a fan of the rear of them but the rest was tasty...Was the dark purple-ish color with some fat TE37's
if anyones got any decent photos of it post em up
yes mohsen, thats the joke. thanks guy.
lol
fail
lol
edit: going cq tonight. anyone frequent that place?
also, are the trim pieces where the tweeters go on r32s, the ones behind the side mirrors, the same in coupes and sedans?
Edited by Mohsen
s14 on 7 series wheels. a reverse funky
For some reason i actually think its looks pretty good...surprised with the guy who done it and pulled it off as a decent lookn car...
I want roof racks for me gtr :D
ok ill buy front pipes first than ecu later on down the track :D
:P
You shall be happy with it!
does anyone else agree the chick from scrubs is hot?
You talking about Elliot Reid and Carla Espinosa..?
anyone got a photo of JDM145?
A S15 with a S14 front?
any spoked wheel with slight concave on an s14 with rails on the floor will look good. bros in oz just don't have the testicular fortitude to rock it.
instead they homo it up by putting cheap shitty URAS kits on their cars and think they're instant drift superstars.
guys in japan have been putting Infiniti FX 4WD wheels on 350z's, skylines and silvias for the last 3 years or so. 19" or 20" + same PCD + perfect fitment for an OEM finish. combined with low it's instant win.
Where do i find it? is it in Sport or Entertainment? Im excited, should be good!!
i think the channel starts in november.
with my new cat that i got it has the sensor hole, should i block it before i install it or doesnt it really matter?
yayyy... got my tax return.
time to drop some cash on 240z mods out of the US while it's cheap as shit
http://www.arizonazcar.com/TRACK-PAK.html
by the time I'm done with this car it'd be the metaphorical equivalent of climbing up on the table and taking a massive dump in australian zed owners' cornflakes.
also...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
