Been without my car all week, depressing shit, dunno how some people leave their cars at mechanics for months on end when you can do everything at home!!
coz they're lazy kunts
had my car almost 3 years now only been to a workshop once for a timing belt change. should've done that myself too
red goes faster
ah ok yeah that is a bit too far i just wanna get the kit and put it in myself, was looking at a DIY on here before, pretty straight forward job.
these MV kits seem to be the most popular but aparently are only available in SA or something?
they send the valvebody to you, then you send your stock one to them once you do the swap. like an exchange kinda deal. lots of ppl in melbs run them
red goes faster
id give mv automatics a call im sure they can work something out or you can try and find my old car because it had the mv automatics shift kit in it lol.
i seeee do they have a website or something?
is there different kits or "stages"? i want the one that helps change gears quicker/instantly
nah last time i checked they didnt have a website. the kit you want is the mv automatics stage II shift kit. i have an article on it in one of my old hot 4's magazine where one of the guys got one of these installed he said it was worth it and once i got one im the same its really good.
For all the work getting done, it's basically the same price to respray the whole car.
Vu said my paint is faded so colour matching won't be 100% perfect anyway, hence the full respray.
Either way, I'm stoked with the price I'm getting! Also getting the front guards pulled at the same time :ermm:
Have fun with that.
at least if Vu misses patches on your car it will be red under red, not white under orange like krysiisisiiisuiisiisisu's first attempt paint job :huh:
sweet. i think i'll wait till one comes up for sale on these forums. its not too urgent atm
Lol, I know you had an issue with Vu... But the job he did on my old car was amazing. I couldn't fault it.
We'll see how this one goes.
how much were you quoted for a full respray if you dont mind me asking?
My car is gonna be gone for 2 weeks while its resprayed :P Then a few 2-dayers for other work like gearbox etc.
Replacement car? My boss's old 1994 Magna. Lovely..
least you don't have to take the train 4/5 days a week
that doesn't say a lot since you couldn't fault a car that had been banana'd. :P
you mean drifteks?
-____-
doesnt pat already have dteks?
learn your wheels you dropkick.
Drifteks are multi-stud and have less aggresive angle on the spokes.
Uras are 5 stud, look much better and a japanese company.
(To Funky; even IF you claim dteks and uras' are made in the same factory, would like to see proof on this, that doesnt mean it is the same. Material, tolerence limits and quality make the product. Just because they are in the same building doesnt mean they all follow the same requirements/limits. )
I'll pay that :)
But seriously, they did a great job. Especially given the crappy asian bodykit I provided them with.
-____-
fuck you. they're both cheap shitty knockoff wheels regardless of where your high and mighty ass wants to source them from. you wanna pull the material tolerance engineering card, fuck your ghetto ass, go get some TE37's and do it right. Don't try and validate your ghettoness.
Uras and Driteks can both suck on my nutts.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
