I don't go out drinking much, half of my mates will blow hundreds on booze and cabs and shit every weekend.. i just can't spare the cash, or the time when i'm written off for the entire day afterwards. i save a lot of the little money i do earn basically :devil:
oh and i won't get to 300rwkw (on 98 fuel at least).. so not in the club :P
cartier watch at oz shop: $9800
same cartier watch in the US + shipping to oz + taxes, duty etc: $7953
same cartier watch, secondhand from the US + certificates + shipping to oz + taxes, duty etc: $6100
there goes this month's paycheque.
I don't go out drinking much, half of my mates will blow hundreds on booze and cabs and shit every weekend.. i just can't spare the cash, or the time when i'm written off for the entire day afterwards. i save a lot of the little money i do earn basically :D
oh and i won't get to 300rwkw (on 98 fuel at least).. so not in the club :devil:
I usually only go out once a week, and when I do I budget $50 max. Predrinks ftw.
And Kris isn't at 300kw either :P But I just say 250+ = 300 club :)
Seems pretty easy to hit around 320rwkw in an MR2. Everyone has been doing it lately.
And Kris isn't at 300kw either :P But I just say 250+ = 300 club :devil:
how much will that cost to do? when you doing it to yours?
Well considering I'd need a forged rebuild too it's probably a bit out of my price range right now but if I waited a little while then I could afford it.
We'll see how it goes.. I might decide to record another album which means bye bye money :P
Who wears watches these days? Let alone paying 6g for one
if you can afford it then go for it. but im still rockin my fossil one that i got for my 19th. been through 4 leather straps and on the second battery. hasnt skipped a beat and i still get people randomly go "nice watch dude"
i'm all for being a brand slut... but 6k is excessive. You could get Armani et al for a fraction of that
lol @ armani watch. way to fag it up. If you're gonna wear an armani watch you might as well go ahead and buy a Swatch watch.
I've got a IWC I bought with my first company bonus (bought it off the CEO :P) and a Patek Phillipe my dad gave me. In the watch world Cartier is kinda mainstream, cos they started out as a jeweler and not a watchmaker. I don't wanna keep wearing a 10k IWC everyday, so the Cartier is to take over casual duties.
when you're working in teh corporate world a good watch says more about you than you can ever hope to get across in a conversation, and can be the difference between sealing a deal or a promotion or calling the shots in a negotiation and slumming it. Its an investment in your career and social life, and doesn't depreciate as much as a car, nor get you labeled as a hoon etc. Hell if you buy the right watch it'll even go up in value.
I don't need to buy it, but I'm gettin in while the exchange rate is good cos I stand to save about $4000. More if I can convince one of the publicists to pick it up and wear it on the way back, so I save on taxes.
i don't know shit about watches. i am sceptical of the extent of influence they have in 'teh corporate world' though.
i just look at the sun to determine the time, like a boss.
EDIT: If it's such a bargain, do it. Crafty work getting some watch mule to wear it on the way back haha
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
