Second hand Cartier watch from US - 6k
Second hand gcg highflow 1k
Nistune and dodgy tune 1k
Highflowed injectors + fuel pump + clutch 1k
2nd hand FMIC $ 200
Add e85, tune past the stock afm on ~25 psi
300rwkw and a Cartier watch all for the price of a new Cartier watch :P
Caution: will be a pig of a car, but you can have both :devil:
It's just that checking the time is a slightly more mundane exercise than going for a spirited drive in a high powered car
nb. i will probably still splurge on a nice watch when i graduate
ill too but not anymore than 1k....6k is just insane...got a armani watch atm myself...so like my watchs to a limit though... lol..
I have the costs of 300rwkw in the format of audio on a CD :P F*ck that sounds lame.
at least it gets you laid. :devil:
I'm all for watches, spend whatever you like. But that's an ugly f**king watch!!
I need a brown strapped white faced watch (the IWC is a black faced black strap and the PP is silver strap and face). Not a fan of the 18k gold around the face, I actually like the plain silver with brown strap Cartier, and I never wear gold jewelery so I'm still undecided. The non gold version is also like 1.5K cheaper. Gold one is signature series though, so holds its value a lot better.
Caution: will be a pig of a car, but you can have both :)
bought a s30 fastback :D no more dyno chasing, it's all about the vintage braaaap braaaap for me now.
This is the zorst I should be getting:
What you guys reckon? I think it sounds alright, considering 3S engines sound like aids normally.
Edited by jezza boii
bought a s30 fastback :P no more dyno chasing, it's all about the vintage braaaap braaaap for me now.
You mad!
Info / pics / what you want to do with it, etc...
Oh did you hear... That "Other" Zed...
wonder if the plates ZOMG are available... that would be sweet on an old Zed... hmmmmmm.
dunno just sent a deposit, waiting for it to get sent to the mechanic to go over it once again and replace any panels etc that might need work before it gets here (cos it'll probably be cheaper). Sold the GTR I got too. Good thing it was still at the shop waiting to get worked on.
I posted a link to the car on J-Spec a while back. It's the Midnight Wangan car.
Ah yeah that's right, the blue one.
You sold the R32 GTR already?
Did you even drive that? ;)
Egad! So sexual...
Hell yeah man!
FFFFFFFFFFFFFUUUUUUUUUUUU!
Damn Nostalgic Tax!
But if you had spare cash around, you'd pay it straight up.
lol no it hadn't even left japan yet.
Man, you don't fuck around that's for sure ;)
But I guess, the easy accessibility you have to high performance imports, you'd see so many of them, you get use to the high turn over...
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
