apparently 300zx headlights are interchangeable with the ones on the lambo diablos :) they're nice cool cars would be an awesome cruiser for summer. any idea what the 98+ ones go for? and how often they come up at auctions?
looks like someone out there is copying your style because it definately looked like yours.
gone are the days when mine was the only red r34 in the hood. there are a few red ones around now but with different kits or wheel usually
i'll make some minor changes when it goes in for a respray :D
too bad the lambo that sported 300zx headlights was also the one with the poorest build quality (when lambo was havin a hard time makin a profit and had just been sold)... at least they painted the inside of the headlight black, which nissan didn't do for a while after.
gg. Call up some mechanics, surely there must have some sitting around doing nothing?
Will do on Monday.
Already got couple people wanting to sell me one, still waiting for reply from one with g/box about price...
Fun times ahead.
Off to work now.
same guy that owns the green 34 CR34M owns that car. was in for major works...picked up today after several long months tongue.gif
GTR-010 is currently in my driveway.
it looked IMMACULATE
i spent about 5 mins looking at it
coilpacks and loom out of the ceffy now. gonna redo the wiring and reheatshrink the lot and then wrap it in heatwrap tape.
chucked in a CA18 coilpack to replace a missing cylinder and it started firing again. so was just faulty coils. huzzah. $80 fix.
also didn't realise, but some fucker's broken a key off in the driver side door lock, and there's signs of someone having tried to force it open. lol never realised cos the alarm was keyless entry. retards must not know about ceffies, they've got the same door lock workaround as R33's. so much easier than forcing a door lock open.
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
