yous feeling generous? :)
just trying to decide what colour to powdercoat the rims. dunno why but im leaning towards black centre/white lip :)
seen it in pics doesnt look bad, bit different...
also trying to decide if i should go with a red/black theme on the car (black bonnet/mirrors/lip) or just plain red all over
I used to have a spider that lived in the side mirror of my old corolla. He was there the entire time I had the car. I would spray the mirror with water every now and again, and surely enough the next day a spider web would reappear. I eventually gave up and just let the spider live there. I mean, who am I to destroy his place of residence? I even affectionately named him, Terence.
saw a massive hunsman run across my bonnet as i was driving. Didnt see where it went. Popped the engine bay soon after and saw it cooked on my turbo heatsheild. lol pwnt
btw let me know if there are any openings for working at hte land of chocolate :)
what position you looking for?
Graduate program closed a couple weeks ago :)
Cadbury bought out by Kraft Foods, so you're better off having a poke around the Kraft website in terms of job vacancies.
They let wogs in friday night, no dice saturday night though
I went there with my (hot) ex and her (hot) friend on a Saturday night. Bouncers didn't want a bar of it. Since then i boycotted the place. TFU is infinity times better anyway :)
No understand?
Hero = shitty skid tyres lol. I have KU31s on the front, they are pretty sweet for the price.
hay mangs
All finished uni for the year dood? Must party soon!
50k to 70k depending on how incompetent you are.
no mohsens need apply. the only thing you could program is a microwave with a hammer.
fixed for accuracy
i honestly dont even know how to program a microwave or any other house hold kitchen appliance, but I do suck a mean cock.
fixed for accuracy
agreed.
lolfag
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
