yous feeling generous? :)
just trying to decide what colour to powdercoat the rims. dunno why but im leaning towards black centre/white lip :)
seen it in pics doesnt look bad, bit different...
also trying to decide if i should go with a red/black theme on the car (black bonnet/mirrors/lip) or just plain red all over
I used to have a spider that lived in the side mirror of my old corolla. He was there the entire time I had the car. I would spray the mirror with water every now and again, and surely enough the next day a spider web would reappear. I eventually gave up and just let the spider live there. I mean, who am I to destroy his place of residence? I even affectionately named him, Terence.
saw a massive hunsman run across my bonnet as i was driving. Didnt see where it went. Popped the engine bay soon after and saw it cooked on my turbo heatsheild. lol pwnt
btw let me know if there are any openings for working at hte land of chocolate :)
what position you looking for?
Graduate program closed a couple weeks ago :)
Cadbury bought out by Kraft Foods, so you're better off having a poke around the Kraft website in terms of job vacancies.
They let wogs in friday night, no dice saturday night though
I went there with my (hot) ex and her (hot) friend on a Saturday night. Bouncers didn't want a bar of it. Since then i boycotted the place. TFU is infinity times better anyway :)
No understand?
Hero = shitty skid tyres lol. I have KU31s on the front, they are pretty sweet for the price.
hay mangs
All finished uni for the year dood? Must party soon!
50k to 70k depending on how incompetent you are.
no mohsens need apply. the only thing you could program is a microwave with a hammer.
fixed for accuracy
i honestly dont even know how to program a microwave or any other house hold kitchen appliance, but I do suck a mean cock.
fixed for accuracy
agreed.
lolfag
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
