i think they should've kept the cars/game play etc of old nfs and just improved the graphics and stuff. the newer tuner style nfs is epic fail
Thats what the new Need for Speed hot pursuit is. Just came out. Was deciding between GT5 and NFS. Got GT5 instead, game is too serious. Needs more lambo police haha
oh shoulda gone nfs then its heaps more enjoyable to play! true gt5 is way too serious. used to play the prologue, not to actually race but just to look up cars and shit it was like looking up cars on the internet lol gets boring quickly even if it has 11ty million cars and real like graphics
its confirmed people are scum, my car has been hit in the parking lot and they drove off with no note im shattered. ive had family members die but this time i was so close to crying looks like ill need a new rear bumper and the tail light shroud peice :D will it be hard for a panel beater to match the midnight purple II colour with the rest of the car?
Stare at it for a few seconds niroj,
Btw, athid to roll guards? Seen hamish recommend him a few times.
There is a guy in Greenvale that does it, both me and Ric had it done by him
Low Down Guard Rolling
Gavin - 0438892344
he also comes to you if you want
Ah shit :(
got any pics of damage?
are there security cameras around this parking lot? if so, go have a look
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
