ask muztek....he works there now...pretty sure they do..but dont think they will be any good ones....for practise should do the job...
i searched this in their site... http://www.jbhifionline.com.au/hi-fi-home-...itar-amp/436081
thanks mate i appreciate that, hopefully they keep them instore because thats all i need just to practise with.
Those mini amps a very cute... But would sound no where near as good as a decent practice amp, which would set him back just under $200, give or take...
Don't bother with Jb Hi Fi.
Goto Billy Hydes / Allens music store.
They have what you need.
i was thinking of going there ill check for the closest one to where i live.
on another note i called up RACV and i can take my car to where ever i like to get repaired, im thinking of taking it to my mates dad who has been doing this stuff for years and as a bonus he only works on expensive cars like the other day he was fixing up a ferrari f430 so id say my car will be in good hands with him.
^^ Sounds like a plan.
guess its up to him to decide.... :(....so hows things going jamie?
Yeah good man, still waiting on NBA JAM for PS3.
Put a deposit down but EB Games can't give me an exact date.
I might goto another EB Games and buy it then cancel my deposit.
Then probably pick up Need For Speed Hot Pursuit while there.
mmmm tasty.
Damn, that is tasty!
I like.
mmmm jury's out.
rear fitment is spot on, over all look seems confused is it vip/luxo or sliding through corners?
too much confusion.
no confusion. looks baller AND slides. best of both worlds.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
