So I'm thinking of getting a new car.
Criteria is it can't be an import, or an aussie car, and don't want to spend more than $25k. Something sporty would be nice, but I'd love a Euro car. Suggestions?
like prinny hwy? for laps. if so lawl.
Lol so many SAU people do it but never say they do ;) Me in the other hand dont care. i go every week lol. Mainly to meet up with mates but enjoy the ol cruise to see who i can destroy.
you'll need to work on your budget if you want a euro thats sporty and not too old..
bmw 330ci
audi b6/7 a4 or a6
maybe vw passat?
most alfa's are porn if your not worried about resale...
how about you buy a car you can actually drive? And I mean somethign within your capabilities... like an excel.
You're a gimp, and I promise you when you write your car off I will laugh long and hard at you.
why do you always have to be so negative?
Modern psychology indicates that people who unnecessarily criticise others are often deeply unhappy. Such individuals may have low self esteem or perhaps may even be depressed. When people are sad or insecure, often the world becomes a very dark place and they see their enemy everywhere. It is at this time they start to 'act out'.Putting down others can also be considered a form of 'projection', in that the aggressor projects onto others what they really feel about themselves. When an insecure person calls someone a 'gimp', really this is a direct reflection of how this person feels about themselves. Accordingly, this person will insist on insulting the other first as a means of escaping these negative, insecure feelings. The more unkind they are, the more distance the aggressor then creates between the victim, resulting in the need to work harder to gain the victim's attention in future online situations. Much like the attention-seeking behaviour of a naughty little child, the aggressor will then try to re-establish this connection via inappropriate means, as highlighted in the above forum post.
My favourite prinny guy is the old dude with the black (blown) monaro. EVERY WEEK he is there haha
Shane, e39 530i?
Mate of ours Malcolm, Supercharged 8 running 380rwkw.
He said he dropped the car off, paid them 10G, picked up car. 380kw LOL
I never hit up prinny.... Fkn ghey shit imho
Scared to find out how slow your car really is :P
haha nuh you're probably working or sitting at home greening out on a friday
    • Just get rid of the orignal low impedance injectors, replace with modern high impedance injectors, and you won't need the resistors. Wire direct, as per any other engine.
    • Tao, we're not talking about the ECU boost ref. We're talking about the wastegate signal source.
    • Flapping up and down is a consequence of the varying pull on the belt. When the engine speed is suddenly increased, the tension in the belt increases too. When that engine accel changes to decel, the tension is reduced and turns up as a little extra length of beltes between the pulling and dragging pulleys. That extra length flaps up, then down. There's all sorts of other harmonic stuff going on too.
    • hello ladies and gentlemen so i’ve swapped a rb26dett into my r33 gtst and ive come across many speed bumps but its nearly over what im having issues with is the injector resistor box that are normally on the RB26 fuse box but im still using my rb25 fuse box and as a result my injectors aren’t getting power and is the last thing i need to figure out so the car can start. can anyone help me out on where i can find a wiring diagram for the rb26 harness to see where the injectors are supposed to receive power
    • The boost pressure at the compressor cover will be higher than at inlet manifold. lets say, trying to hold 20 psi flat at 7000 RPM. If your wastegate opens at 20 psi measured at the compressor cover, the engine may only be seeing 16 psi. Your base pressure reading at engine would be 20psi by 4K and 16psi by 7K while your MAP at compressor housing still reads 20psi at 7K. For this reason your ECU's MAP source is never on the compressor cover. This difference isn't a major concern if you're using an electronic boost controller (EBC).
