15.5k for 270rwkw 32 V Spec.with RWC.
Mods are the following;
R34 N1 turbos + dump pipe with HKS actuators.
Power FC.
Nismo Front pipe,
3" Hi flow cat.
3" Cat delete pipe
Apexi N1 cat back.
Apexi RSM.
Apexi pod filters.
Pair of Recaro SR3 seats.
Tein Coilovers.
Whteline Swaybar (F + R)
Adjustable cam gears.
HKS EBC (EVC4 i think).
Apexi Pen turbo timer.
Nismo Gearknob.
17x9 +19 SSR Evolution Wheels.
Have standard exhaust, suspension, airbox.
Sounds good man!
The standard air box you have... Do you have the whole setup including the cold air intake?
The part that slides into the part under the head light?
If you are interested in selling it, I will want it as I am going to use it for a modified CAI.
Sounds good man!
Yes I do have the whole she-bang, not interested in selling it at this stage.
jetta is good my parents have one, drives nice what about accord eurO?
That's another thought, but IMO the ones around my price range are beggining to look a little dated, as compared with the current model. With the Jetta, even a 06-07 is still the same shape as the current model. Plus that chrome grill looks sexy :D
More inspiration:
18x9.5 +24
18z11 +20
Half of boot is fillwd with dynmat, need to remove them along with wires for stereo...
FCC3 Handcontroller doesn't work with RB26 based Power FC, need to buy FCC NT or something? Need to look few pages back or just PM Paul.
so just dont modify it more till you can aford it douchebag
lolz
its like when people say "need to sell car to invest in property" or whatever.
if you cant afford to keep your car you shouldnt even be looking at moving out or buying property coz chances are you wont be able to afford that anyway.
  • Like 1
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
