does it only happen when cold? unplug the IAC plug and see if the idle changes.
Sms'd a friend, he confirmed it's vacuum leak so getting it looked asap
Grant thinking of selling? 32Rs starting to grow on me..
At this point, I could be tempted but I'd have to buy something other than skyline (had 6 of them) but no idea what I'd like to get though.
i see what you did thurr haha
grr i hate my car, no one responded to my rant last night about it. sad life
Surely it can't be that bad. What do you hate about it?
Haven't you just errrr, 'invested' a whole bunch of cash into it? Surely it should be keeping you satisfied ALL THE TIME. Kinda like when you 'invest' in diamonds for your girlfriend...I mean, she'll pretty much have to right?
Lol, my gtr gives me problems too, currently its a hunting idle, and a dodgy clutch pedal feel, sometimes hard, sometimes soft, like a dick.
but i'm 7000+kms away from my car and i can't give a f**k, she'll buff right out, except that EPA notice...
i painted the dash in the evo recently cause it was all scratched from previous owner
went adark gunmetal and turned out awesome, id recommend the colour to go with white to
in the sun its got some nice silver specks in it :)
Oh that sounds awesome. Basically I want to give the impression that the painted pieces were a factory thing, know what I mean?
Like in my mate's silvia. Half teh dash is black (like my '33), but there are silver / gunmetal parts throughout and it looks really modern and classy instead of single-colour conservative black like mine is right now.
yeah i have.. but it's just like every other white r33 out there (like yours haha)... it's quick but i want it to look better.
thinking stealth wing and coilovers should keep me happy for a while
haha ive earnt enough lately, need to waste :P
although i didnt lose as much as i expected to last weekend LOL
I love when that happens. Once I woke up in a completely different suburb after an insane night out and had more money in my pocket than when I started the night.
Just pulled the condom out of my arse and merrily walked home.
Dude, I think exactly the same sometimes. There's just so many of them around it's nigh on impossible to be unique lol.
yeah well this looks factory, but better than what the evo's came out with
it was Holts Dupli-Color
DSS703 - Charcoal Grey Metallic
I used 2 cans for the dash, and gearshift surrounds was a sorta big area
  • Like 1
hahaha
got a price in mind if you were to sell? yeah you need a change lol
haha sell yours first then buy another car :P
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
