What business you doing?
Car washing/detailing :) I start my training in a week or so.
Like I'm good at that shit already (washed my cars 2+ times a week for the past 2 years) but I need to learn the professional techniques before I'm confident enough to let loose on a $100k Mercedes :P
Think so, check the box on fb
Edit: bf series
Lol might be a fake gauge then. As only the racer series were able to be used without the cotrol box. And would explain why it doesn't work. A boost gauge is a very simple mechanism
Ah yes!
I remember talking about that to you last year... Or was it earlier this year...
There is a training course for car washing?
Yeh it is a fakey. I think I got the connections wrong. I'll have to check everything again when i get home
Ah yes!
Was probably someone else, coz I only came up with the idea recently.
I'm not doing a course, just getting trained up by someone who does it for a job already.
Have also been watching a lot of online guides. With the 2 combined I should be off to a good start :)
Yeah it was you, I remember telling you to budget out your car wash equipment, like Car Wash Solution / Polish Solution / Sponges / Shammies etc.
:D
wouldnt that have been a good business 5 + years ago? my mate runs a car wash rkns its going backwards hard since people can wash there cars at home etc.
Nah, heaps of rich kents in my area still take their car down to places like "Suds @ Mentone" to get their cars washed coz they don't have time to do it themselves.
I'm taking it one step further and going MOBILE so they don't even have to leave their own house. Ultimate convenience :) And cheap business to start up.
If it all fails then I can just use all the materials to wash my own car :P Can't really lose.
Edited by jezza boii
Man I got an apexi gauge fake. Told the gut to get f**ked and returned it. It would not work. They are all shit. Tried to get it to work for hours and couldn't. Went and got a real apexi. 2 seconds and it all worked
what ever you do, dont drop the sponge and continue rubbing the car with it
watched the vcals do this while they were cleaning the teachers cars.... lulz were had
kris- i got mine off a trader on here, knew it was fake, seems legit. ill see how i go, if it wont work ill give him a buz
Edited by Mohsen
So an Sau trader is selling counterfeit defi gauges? Wow :s
:rofl:
Jizz boy got a pay rise, or his "Band" must be kickin' off.
Only thing sadder than taking a photo of money is taking a photo of money with f**k all money in it.
im driving to sydney tomorrow. dont ask why im driving
I drove there for last years footy trip. Left at about 5-6am and drove there all alone, only stopped once for petrol and food...It wasn't too hard at all. A thermos of black coffee meant I didn't yawn once the whole way there (had about 3 hours sleep the night before), and I can't even drive 25-30 mins to/from work without yawning like 10-20 times lol
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
