aircons not going cold after over ride, ffs re-gas
also, brilliant idea, i work for my dad and uncle right, uncles more than happy to write up a paper saying im driving around in the car for work for PROMO purposes, meaning, box of cards and flyers. where ever you go, there are eateries, cop asks where, im doing promo work
f**k yeah
flame suit on
Lol, although i shouldn't be saying this, i'm saving for another supra. =x
Soft.
buy my shit :(
clicky clicky
:( and aren't you getting new rims? If so, sell them not the Professors.
Haha kk mate. Let's put it this way. No cars on the hwy could beat us. The car is bloody ridiculous. Joshs forum name is CR34M
Don't plan on beating you (I'd set it on fire before doing anything smart), shall PM him.
f**k yeah
flame suit on
Go for it I say.
f**k yeah
flame suit on
make sure your promo pack includes lube.
lol wouldn't you want to know what pressure the actuator is rated at first? also, why not just buy a garett actuator? same shit, just a rod attached to a diapragm.
saw his forsale thread which mentioned the pressure rating. Easier to hassle through wasteland.
Been in talks with GCG regarding garett actuators. If i can get a second hand hks for cheaper, that would be better!
pat- my aircons blowing hot air..
The plug which connects the blend-door servo motor is playing up. Pushing it to the left/right should improve the connection. Its located right behind the headunit. I pulled mine out and rebuilt it (resoldered all the connections etc)
dw, found some pics that pat posted
:cool:
If you rip it out from behind the dash, my dad can fix it for you. (Owns a tv/electrical repair business)
Fixing problems down to a component level is a dieing skill :(
Now its all about replacing full boards which cost $600+
tried the over ride that shan highlighted last night, wasnt cool air, or does the servo still play a part?
it relates.
Stick your head near the passenger footwell and find the plug/metal rod as seen in my pictures. Then move the temperature up/down and see if the rod moves. If it doesnt, jiggle the plug and repeat. See if it moves.
The override means the rod swings all the way to cold position, but if there isnt a proper connection it aint going to move anyways
going to repco to check out their 20% off sale. anything worth getting?
actually might pick up some spark plugs n oils shiz.
got my collated coil nail gun and started using it to do some racking in the garage... man the shit's lethal, at 120psi it fires the nail into hardwood so hard that it rebates it 3mm into the wood. gotta dial it down to 90psi for flushness.
just got back from Anglesea/Lorne tuff weekend. sleeping with foxes, hand sized spiders and all kinds of insects was fun. nice to be back to a clean home with a comfy bed
license back in 3 days :cheers:
I got mine now. burn, although, family courier driver FTL :/
Pat- got the connections working, swung to cold but no cold. Gonna get It regassed when I go to work/ no longer poor :D
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
