ok hang on so the $2802 is what i pay per year and the "excess" which is $1600 is what i pay in an event of an accident etc? 3046 much safer than 3047 :P
what do yous pay then for your premiums?
With Shannons, Rating 1;
Cube - daily use cover, Skyline - extreme limited use cover, Pulsar - laid-up cover, approx. $170 per month.
If one's ecr33 diff has gone from a twin spinner to a single spinner akin to that of a VN commodore, what should one do?
options are:
shim
weld
replace with GTR diff
replace with real diff
all of these better than standard diff
options are:
shim
weld
Replace with GTR diff you say?
What benefit would this have over say, a train... which i can also afford.
options are:
shim
weld
Shim = what i will be doing
Weld = f**k that
GTR diff = will need to replace both half shafts as GTR is 6 bolt and GTST is 5 bolt
Replace with real diff = expensive and if u buy a shit one like i did it will explode nicely LOL
$10/month X 12 months = $120
is this your r33 or? why so cheap you must have a spotless license or something..
u think thats bad i remember being quoted somewhere round 5-6k full comp back in 2003 as a p plater r34 gtt think just cars or shannons.....
now $290 third party just cars.....
not surprised for a p plater i dont know what p plater would be able to afford that just for insurance anyway
thats not too bad for 3 cars but why do you need 3 cars for :/ i can understand 2 if you had 1 daily in which case i'd get a shitter thats not even worth insuring so i'd still only pay for 1
On a scale of 1 to Miley Cyrus, how illegal is shimming a diff?
you can shim a diff as tightly as you want, you can shim it for minimum lock or shim it so that it skips like a 2 way. Up to you.
With legality, its like anything if cops see it skipping they might say something, i have never had a prob with cops with the 2 way, they saw it skipping along the ground and didnt say anything
options are:
shim
weld
just went out for a drive to prac my heel and toe technique.......master :whistling: i notice that my diff feels a bit sad maybe its these f@#%in ku36's dnt like em time to get a real
diff nismo 1.5 or 2 way? yea boiii...
3 litre is probably cheaper
f**k welding the diff or GTR diff
either shim your current one or new kazz centre or nismo centre
do it once and do it properly
stuff changing in / out 2nd hand parts etc
kaaz 1.5
do it and you can thank me later.
shimming's good fun if you own a beat up 32, but if you want it to last, do it properly. Put it this way... ALL the power you make has to go through it. If you wanna wager that on a $1.50 shim go nuts.
shimming just increases the bite point of your viscous, which means there's still slip, as time goes on it'll wear down and cark your diff. Guaranteed. Unless you're prepared to pull down and flush pumpkins after every track day or major fang session.
kaaz 1.5
why kazz? they better?
??? how else do you drive around? I heel/toe for daily driving.
    • I'd need to check my notes at work Duncan, but I'm pretty sure most of that is purely OBD2 on the display. How quickly is it all able to update? Do you have any internet capability in your workshop with a laptop?
    • Yeah just gonna be near stock runner only want 180kw to 210kw can’t find anything been looking ages looked in to rb25 but money is tight as the moment need the car back on the road
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
