yeah peak power is only one part of the picture
if you look at my car its peak is pretty ordinary, 191 rwkw was its max
but the diff gears, lateral acceleration, suspension etc give it the quick accleration
able to beat most cars on "private roads" and was ever so slightly pulling away from a 315kw r8 ute on another "private road"
i still reckon on the street an 04 sti would be even - i dont know about "rip"
You were pulling away from a 315kw r8 in essentially a stock skyline. Me no believe
yep i kid you not
was about maybe 1.5 years ago
on a "private road" we both hit at 100km/h and i backed off we went ticked past $1.80
it was a blue R8 ute with the 315 badge on the rear of it, no idea if it was auto or manual
i was pulling away ever so slightly, only just
that was basic GTST with sub 190rwkw
my best 0 to 100 was 4.88 back in the old day
Maybe the guy couldn't drive lol. I managed to go door to door with those ve walkinshaw supercharged sedans on my private road. Later found out he had 357rwkw. I guess the weight kills those cars
Lol @ commodores. You'd hope 6 litres and FI would get you better than a mid 12...
  • Like 1
was getting paid last night to do absolutely nothing because the floors at work were too wet and slippery from the humidity...then when they finally got the place dried out enough to work, 2 hours had passed, so then had to work back til 4am meaning even higher pay rate...now they're behind so I'll be able to do the same tonight lol..good ole' humidity
FYI
pauls car = ~145rwkw/tonne
315 "kw" conformadore = ~250rwkw = ~145rwkw/tonne
power to weight is dead even
that's a rough calc taking your car as 1350kg and the R8 @ 1750kg with a drivetrain loss of 20%
fwiw on e85 my car is ~100rwkw/tonne more than holden's finest lol
lol...
it runs right past my house so make sure you drop in
will do. need monies soon to pay for engine build. they've got the EFI kit on the LS5 now, but they haven't got it running yet. Engine's good for 350 killabees with no EFI, so hopefully with it, should run a lot smoother and more powah.
Then if I have any money left over after moving later in the year strap a supercharger to it for even moar powah.
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
    • I don't know what globes/headlight connector they run, but I'd be looking for a female adapter to plug into the existing headlight on one side. Something like this https://www.ebay.com.au/itm/256017245989 Then I'd use a pair of single input, double output relays (one for low, one for high), mount them in a spare space in the fuse box if you want to to look more original (and be easier to maintain). Then 2 new power sources from the main stud in the fuse box via a fuse to each relay. Low from the headlight adapter pin triggers low relay and high from the high headlight adapter pin triggers high and low. Earth the relays and new headlight sockets and off you go. Because it triggers off the original headlight all of the dipping/hi on/high flash all still works
    • I reached 10 posts and wanted to make my build thread too but still can't add pictures to posts so I have no idea how it works 😂
