dont go over board on the orange i mean mirrors / bootlip will just be plain gayunr33l. u dont want to go that low the thing looks insane
glad someone said it, that will look f**king ridiculous
low doesnt look good on r33 gtr's imo. and you wont be able to drive it spiritedly on most roads coz it will constantly be scraping etceverytime i see a clean 33R it makes me want one more than anything else. f**k i love that car
so get one, $30k left in your pocket for mods over an M3
Wont be going as low as that pic maybe a inch lower then what I'm currently sitting at - because yeh its meant to be driven hard :P
yeah man inch will be perfect i rkn no more.
gtrs just dont suit super slammed imo. will give your car a tough stance all its missing is low :thumbsup:
Really? That must of been sweet. jeebus look at the deposit you gotta leave to hire one lol.
Pics here;
http://www.skylinesaustralia.com/forums/topic/345855-lamborghiniferraripagani-museum-tour/page__p__5570092#entry5570092
true, although its a bit of a gamble. Just basing off other designs out there. Surely the below arent horrible?
Black%20body%20%26%20orange%20stripes,%20Chevrolet%20Sonic%20Z-Spec%20concept%20%281%29.jpg
*In for bagging of Mohsen for getting lost on his own after the line was 30 cars long :D
lmao i couldnt see shit in the fog, saw leigh turn off, thought something was up so i followed him into a side street.. turns out he was going home haha
will bring a CB next time and damnnnn my car looked so shit compared to everyone else, now i know what all the r32/ 4 door hating is all about baha
man all those cars arent in the league of a 32 no offence meant.
and the last one is farking aids.
im all for orange wheels if its kitted up and ya nuts hang low.
otherwise for a clean look id go silver OR a nice midnight blue custom wheel colour on black would look dope AND no body else is rocking that shit. :thumbsup:
haha yeah i know.
Will give it a think over, rims wont be in for another 2 months anyways, so will prob change mind about colours during haha
    • Ok sounds good. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
