I never had issues with my previous GTR and my current GTR both has aftermarket turbos and noisy exhaust (granted that I don't drive 32R much).
It sounds like you're after stockest of the stock. Good luck finding one.
consider yourself lucky then. i dont remember the last time i took my car out without a cop atleast eye balling me, while im shitting bricks hoping he doesnt turn on his sirens. cbf anymore wayyyy over it
australians need to get some knackers and start protesting about shit they arent happy about like 90% of other countries in teh world.
i want my donation back $20+ a month is a lot of money i could use elsewhere.
on another note, i fkn hate labor governments and i'm never donating again! theiving scum.
thank god i voted liberal and can blame everyone else who voted labor
Let's be friends.
Now to invent fanciful deductions to offset the levy mwahaha
sweet, I'll go through it
im still keeping the M3 and a 34R as options but atm leaning towards the 33. fml.
If the 34R is a realistic option, I wouldn't bother with the 33R...
Washed car and touched up stone chips and re did clear coat on front lip :)
Took a few pics as well:
inb4 "MOAR LOW"
Needs more low!
:D
+1. Labor can suck my wang.
You want Julia Gillard wrapped you?
:laugh:
As for the orange wheels, I wouldn't be using supercars and full body decaled drift cars to convince myself something will look good, because they won't look like that on your car
true that.
Pat, your R32 is not a GT3... :laugh:
Go White or Bronze for a clean look.
If you want a tough look go Black.
never said its a gt3, just admiring the colour scheme :P
white, bronze, black is boring, stop having a boring life. /slapchop
Fk it, ill stick with my offset fail drifteks :domokun:
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
