yeah if you want to see how loud it is try that
i did that when i first got my gtst and couldnt work out why it was so quiet vs other skylines i had heard
took the top lid off the stock panel box and took out the panel filter then when for a quikc burn
my god - suck induction spool noise - it was awesome
didnt do it for long only 2 mninutes then got a pod sorted out
lol then the filter will just fall out
why?
ive had my lid off for aslong as i can remember, sounds like a jet. f**k taking pod off every time you get defected..
also, are there any differences between 95/96 33Rs and 98 series 3s? other than different colour interiors?
Dropped my car off at the same place it was at for 14 months, for a 'week' for them to finish 'some™' electical issues (about 25 of them).
Chances of seeing this car in 1 week, I'm wagering low.
95 has blue interior with one airbag. 96 has dual airbags and pretty much same dash as r33 gtst s2 with blue interior. 97-98 has red interior. Carbon look cluster. Xenon headlights. It's primarily cosmetic but if anyone is to buy a GTR I would get a series 3
ah ok yeah not many series 3s pop up for sale though
airbox lid off can't be a good idea....it's there to keep the air temp down, otherwise it's just sucking the hottest possible air available straight from the bay
a pod would be worse though for sucking hot air. unless its properly shielded or something
Still haven't got it back?
I got it back.. sort of. There was a lot of.. outstanding issues.. which are now getting looked at... I'll update my sig for the lulz.
lol did they charge you to tow it when they moved? ;)
They only moved about 100 metres in the end.. that said I wouldn't mind if someone accidentally towed this thing off a cliff. It's pretty much the worst car ever..
Kris is correct :)
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
