rage?
how much was a new one from toyota?
$2500 from the US, plus shipment which would be ridiculous.
I talked to the guy that sent me this one though and he said it was tested before it was sent from Japan and ran fine. So no idea what's going on.
Just gonna have to pull the box out again and replace whatever is causing the problem. Might actually be the diff (yes they're in the gearbox on transverse engines)
Either way, labor costs will be insane. Thank goodness for credit cards.
Camaro ss faced ute spotted in melbourne. thoughts?
http://www.caradvice.com.au/92019/holden-commodore-ss-camaro-ute/
looks sweet. mind you I've got a soft spot for camaros having owned a gen 2. I'd probably get the frontend conversion kit if I ever bought a VE wagon (probably the only VE I'd buy).
also, nga's in oz have no probs grafting an S15 front onto a clapped out piece of shit S13 but think doing something similar on a bogan sled is wrong? you and your high horse can both fuck off.
so one of my friends got kicked out of the pub, she was too drunk we took her home, and more of her friends rocked up, then got ditched by my lift to take more girls out to a club - feels good man I guess it aint bros over hoes for him
you for real? my asshole looks better than that! :no:
You still need 'Spark' to get power... I assume the bigger / better the spark, more so, the car runs smoother, rather then more powerful.
:blink: no.
there's a limit to how much power your sparkplug can discharge, so no matter if you pump 11ty billion amps down it using your overpriced splitfires or just pump the necessary amount using brand new factory ones, the sparkplug is gonna spark the same. Once you have a spark, you have combustion, which generates your power. Up until then your car generates 0 power. In fact it just consumes it.
Put it this way, if a terrorist was to blow himself up and had 1kg of TNT strapped to him, and had the option of a $2 switch and a $200 switch, both of which work properly, which switch do you think will give you the bigger explosion?
Half the time people start sporting boners for splitfires and rave on about how much extra power they're getting, it's because they've just replaced their factory ones that are about 10-15 years old with brand new ones.
you can wire up a cheap MSD transformer setup for about $200 that will give you the same spark as any splitfires, any day. fact. not quite as simple as unplug and plug, but it's possible.
lol fine for driving manual on auto license is 90 bux no points
MANUAL IT IS!:thumbsup:
I got 150 fine for that, and that was even when I had my re-test booked in :( f**king good for nothing police cant give you a break.
Reminds me when I got pulled over, around the corner from where a lady got killed at a servo. (Remember that guy that decided to light someone on fire)
:blink: no.
Yeah true that.
What you said there is what I was trying to get at :laugh:
i love bayswater
best place to be!
:blink: no.
The only reason people buy splitfires is because brand new factory coils cost a fortune. Don't think it has anything to do with power lol
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
