go to hillside exhausts in furntree gully they have a $100 thing where they put temp exhaust on you go clear EPA, then they wack your old system back on :) they had a 32 exhaust i think, but had to slightly modify it to fit my 33 but because jay is a champ didnt charge me any extra
SWEET.
So taking immaculate conception into account, and IVF
It's possible ye?
what are you on about?
lol, their car got trashed and they offered me a reasonable price for my car so yeh, just need to remove the boost tee and get a new bonnet lever handle for road worthy.
is that the one were he breaks his leg tryina kick down a tree? lol
that guy was and pretty much still is my idol eventhough he cant act
That's the one...cuts it to the bone, don't think it's broken though coz he keeps walking/fighting
Was trying to find racepace today.. driving down the road.. where is it? oh 10 gtrs right there out the front.. i figure that must be it :D
Got quoted about 600 for 100k service with cam gears put on (with my parts I already have) water pump fuel filter and all the shit. What you guys recon?
www.revzone.com.au for a second quote.
Did my 200k service. I was down there last week and they had a r35 GTR with the engine pulled out. Engine has to come out when upgrading turbos as the manifold is attached to the turbos
Just to clarify, the bonnet latch handle in he r32s, is It one piece from the front of the bonnet to the cabin? Or can I undo It and buy a new handle.. Need one for road worthy..
bonnet latch is attached to the cable. You would need to replace the whole cable i believe. Someone snapped the plastic handle?
ffs, theres a nut before the cable, tighten the tension?
looks like ill be going to jap heaven this weekend, oh joy
did you replace it??
i dunno why they have to be oem, i had a look at the handle when it snapped and their weak as shit, so i made a stainless steel ring that i would weld onto the pin that the handle sits on. but noooooo has to be oem
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
