I'd take that merc over anything and everything. Pulled up next to one at the lights some months ago, b
Tuffest thing ive ever seen. So fkn phat and the sound :O
How bout the pearl white 430 scuderia with the black wheels?
indeed, ugly.
the f**k....
pro fb post, brought many a lol
493kw mang.. and they look even more mental irl
Sif buy a 300k Maserati over that thing
meh dont rate it that much for $530k
you sure if there is only 9 in the country what are teh odds of pulling up next to one?
No probs brah... Just had some knob juggler work shop try rip me for a new one because it's "detectable" for those wondering what I'm on about, I like to drive with my penis hanging out the window.
made a video for lulz with Ita Buttrose
made the ABC news and the Age/Fairfax homepage... apparently it casts her in a bad light. you know, cos cheesy rap to plug a book is srs bzns.
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
