did some spur of the moment fishing today with a couple mates. lost a rod/reel :/ thing went down in the water quickly...
haha was next to a BMW 4WD at traffic lights. I was on the merging lane just after the lights. Lights go green and I casually take off planning to merge infront of the 4wd. As i start crawling off the line, the 4wd launches off hitting the rev limiter and shoots off. Saw on the back that it was a BMW x5 M haha, was not expecting that to happen ~_~
4.4ltr v8 twin turbo 400kw ownage haha
aslong as you dont try and take on a porsche cayenne you'll be fine :P f**k those things fly
i got ALOT of hooks.. LOL anyone need hooks, i got hooks
anyone have a net? alvin- theres alot of small bait fish under the pier, if we had a net we could have put out some livies for the bigger fish to smash
An X5 M is no slouch either
So we ran them down the drag strip. The Cayenne did a 4.7 second 0-100km/h time on the way to a 12.9 second time for the 400m dash, while the BMW X5 M did 4.8 second 0-100km/h on the way to a 13.0 for the 400 metre dash. Call it hair-splitting, but that's how they ended up.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
