2 onions brunoised (2x2x2ml cubes)
1 carrot brunoised
2 stick's cellery brunoised
5 cloves garlic - minced
cook all in 50g butter and 50ml olive oil on lowest possible temp for 15 min
remove from pot and strain. add butter/oil back to pot (remember to have a bowl under strainer to retain fats/juices)
allow butter/oil to heat again and add 500g pork mince, brown
remove pork from pot and add to strainer.
place butter/oil/porkfat in pot and reheat
add 500g beef mince (fatty shit - not heartsmart crap) and brown.
remove from pot and add to strainer.
get bare pot stupid hot then add 1/2 bottle shiraz to deglaze.
once wine is boiling, add contents of strainer to pot.
while meat is simmering, add 400ml tomato paste and 10 chopped vine ripened tomatoes
add salt to mix
in a clean chux cloth place 2 star anise, 3 bayleaves, 1 sprig of rosemary and the vine's from the tomatoes. tie this closed with cooking twine and place in simmering pot. cover with lid
simmer on lowest posssible flame for 3 hours stirring every 15 mins
remove lid and simmer until desired consistency is reached, add salt and pepper to taste, allow to sit.
set aside, cook pasta, mix and enjoy
1 carrot brunoised
place butter/oil/porkfat to pot and reheat
while meat is simmering, add 400ml tomato paste and chopped 10 vine ripened tomatoes
add salt to mix
I'll be at your house in a minute!
sounds good, copy pasted and saved.. i'd omit the celery though.
the celery is integral to adding a base flavour... it's called a soffritto, which is the itallian version of a mirepoix. google "mirepoix" to see what i'm on about. it's the most important part of sooooo many classic dishes
joe when do i get my members status huh huh, come on you is bosss now make it happen,
Dont make me email you... :P
EDIT>> DW Im not gunna tag along your GOR cruise, missus getting tonsils out so i gotta play nurse and do my daddy duties.. :(
Edited by Arthur T3
but because its 2mm cubes, i wont get to taste it and get punched in the face with the taste of apiol right? that is what i'm most fearful of, i can't stand the smell of celery, let alone the taste of it by itself.
i just made the best bolognaise ever... no shit..
shit took 5 hours
I would love to taste your bolognaise.. my favourite meal. Make some next SAU meet? cheers brah.
I think I'm the only one that has eaten your food here, back when I borrowed your steering wheel :thumbsup:
I would love to taste your cawk.. my favourite meal. Make some next SAU meet? cheers brah.
lol wut
down for gor if my membership is thru by then( paying on monday).
brabus tuned s600 v12 sounds sexy :D
Brabus = definition of tuff
no amount of negative offset will ever come close to a Brabus tuned black on black merc.
I finished the steak in about 15 minutes, but it gets pretty hard to chew when you're eating that fast... same for the vegies, there's so much food there that it starts to get cold...wedges etc don't go down so easily as they get colder...
eye see.
veyron
It's probably one of the ugliest supercars in existence
it's the fact that it can rip a 2.5 sec o-100 and be as easy to drive to the milk bar as a stock commodore.
that's why it's a quad turbo W16, not a 2.5lt I6 running a T61 @ 75 psi
easy to drive to the milk bar, question is will you ever park it at the milk bar/shops? i doubt it.. so whats the point :rolleyes:
only reason you'd get a car like that is for investment, hoping it will keep appreciating in price
rather get me 2 or 3 more road friendly ferraris/porsches instead of 1 veyron that will most likely never see the road.
lol wut
Small wonder you're a virgin.
Stop liking other man's penis.
Douchebag.
So I've been thinkin of buying a Maserati 4200GT later this year. They're cheap as chips in the UK, and you get a high revving Ferrari V8. Handles like shit when stock, but is tail happy and fun to drive as long as you get a manual with a gear stick and not a manual with paddles. Should have one landed in OZ for about 50K for an average quality one. That's poverty spec BMW/R34 GTR money for a Ferrari powered luxury cruiser.
Spend another 20k to slam it on its arse and run some decent fitment wheels, maybe spend a little more and change the tail lights to the signature 3200GT ones and put in a 2007 Gransport front grille, bumpers and side skirts and instant panty dropper. Could easily flip it for 90 - 100K in a year or two.
someone convince me this is a bad idea.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
