Vic Wasteland Thread
paulr33
Cars booked in for 100k service / cam gears to go on woo just went to racepace local to me and they know there Rs
Billy, Kris told you so :P
I'm at 501 pages, you gotta up the posts per page :thumbsup:
Anyone know a cop-free safety zone for running in figure 8s?
Nice!!!
My 2 way is fairly clunky and kinda worrying in the wet haha
Is it a KAAZ? Did you put it in recently? 2 ways tend to clunk alot anyway, but it's supposed to get better after the first oil change. Have them in the race cars and they are great on track, but my 'line is also a daily and 1.5 seemed a good compromise.
Birds where'd you get the diff from?
eBay, friend.
eBay, friend.
Try Laverton if your in the West :)
Its Cusco, i just put it in on Saturday :) Once its warm its good. In the dry I can deal with it easy but in the wet its just dangerous, especially with cheap shitty tyres.
Have Fun haha
Had a customer call me non stop for 2 hours... 9 missed calls 15 messages.. And we haven't even made a deal yet. Wtfs wrong with calling the office. I dont work Monday afternoons
A little boy wakes up three nights in a row when he hears a thumping sound coming from his parents bedroom. Finally, one morning he goes to his mom and says, "Mommy, every night I hear you and daddy making noise and when I look in you're bouncing up and down on him."His mom is taken by surprise and says. "Oh ... well I'm bouncing on his stomach because he's fat and that makes him thin again."The boy says, "That won't work."His mom says, "Why?"The boy replies. "Because the lady next door comes by after you leave each day and blows him back up!"
So, thinking of an Evo V, VI or VI TME. Can get most under $20k too which is a plus. Hmmm....
V's are the best of the 3
At the heart of every Evo driver this is a craving for Banana. End of story.
That beeing said, I can't see the point in a TME over the 6. You're going to ditch the dampers and springs, tune etc etc etc
Getting hold of a TME turbo isn't that hard if you want the pimp Ti turbine wheel etc
TME isnt all its made out to be, your better off getting a 9RS turbo, can hold antilag etc as well... much stronger
bangs gets wayyyyyyyyyy to many views considering his lack of talent, it is LOL worthy thats all i could put it down to.
i wonder which fools tell him its a good idea for him to make that shit? like really... they aint yo freinds buddy
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
