Vic Wasteland Thread
paulr33
wow that would be a fun car to have. i agree with sounding scary with one of those coming up behind you i love it. would love to see what it feels like to be in a supercharged v8 one day.
on another note went and saw Millencolin and Pennywise last night and it was awesome, cant wait to see them again at soundwave :D
I was there too!
Was a good show.
F*** where were they playing? How did I miss that?
Supercharged V8 does feel scary, well scarier being the passenger IMO...especially in such a big car. Feel like you're going to crash just accelerating in a straight line lol.
they played at the palace theatre. they are playing at soundwave also if your going.
sc'ed 8 is where its at. power is there whenever you want it, dont have to go make yourself a cup of tea while your turbo spools up etc
cousin's old vy r8 had a 18psi pulley from memory and even with straight pipes when he put his foot down you can clearly hear the sc whine over the exhaust. was quite the animal.
mmm maybe a kompressor merc clk or e-class and mod it. would be different...
did you go in the pit? i was in there for a bit but got sick of being hit in the head from the non stop crowd surfers lol.
I was to the right hand side of the pit, closer to the stage.
Did you see the guy stage dive?
He jumped towards me, I put my hands up to catch him / guide him and then no one caught him behind me.
Then you hear this "THUD" noise as he hits the floor.
He as in so much pain he could not get up.
Pennywise mosh pit had no one, everyone was there to see Millencolin.
Well there was room around me in the Pennywise pit.
Over all a good show / performance from the bands.
I like this... despite the fact it's a R32.
20k for that skyline.... is it even street rego possible?
Good question.
They being dealers, they may have a way. But once again they could be bullshitting you with power figures and 'stroked motor'
I wouldn't mind a go in an (aftermarket) supercharged 8... shame they are owned almost exclusively by bogans :ninja:
white 32 is too much of a beater for my liking, GTR is win however :D
^^ With a big enough turbo, sure.
Also, my radiator is pretty much toast. Does anyone know where I can get an OEM replacement? Cbf with shiny ass china spec alloy ones :)
i did see the guy stage dive, at that point i was standing a little bit to the right near the stairs, i was going to give the guy a hand but a few other people were already helping him up and taking over to the security guys. yeah during millencolin you couldnt move but when pennywise came out there was plenty of room i was in the mosh for a bit with them but then moved aside to watch, my legs were killing me that was to much standing up lol.
At least 300rwkw at 7psi and low mount?
Try wreckers or recondition your one?
Yeah i suppose they are bullshitting then. Haha i didn't look at the ad to notice the setup.
I'm chasing a new radiator, so wrecker won't do. Will look into getting mine reconditioned
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
    • I have two questions here, The first is regarding the harness attached to the power window and central locking control on the drivers door. I can't understand why the previous owner would join these wires together on the harness and why they did such a shit job. There was a wire with 10v hanging in the open un insulated. The OEM remote control works just fine The second is regarding the blue, green wire attached to what I believe is the lock actuator? These were running to the old immobiliser connected to the 'UNLOCK - COM' and 'LOCK - COM' wires. I imagine COM means communication and they just send a signal to the immobiliser whether the car is locked/unlocked?  IMG_9032.HEIC IMG_9037.HEIC IMG_9038.HEIC IMG_9041.HEIC
    • A name I haven't seen in a while, welcome back. Nothing much has changed, we are all still deluded Nissan owners.
