my alloy radiator was like $300ish from memory, couldn't get the car to overheat if I tried :)
can only find china ones for that price.. been burnt one too many times so i'm pretty hesitant. will investigate further though, cheers
can't remember which one I got, but like I said, did it's job perfectly, fit no worries, factory shroud etc. Couldn't get the water temp up to anything to worry about if you tried.
If you can find my for sale thread, it'll probably be listed in there
I got no idea where its from. I just googled it. Best Pho in melbourne is Hung Voung @ Footscray. ;]
no way!... Pho Chu The in victoria st is where it's at! (they do have one in footscray too but i havent been there)
mate got his nitro rc road car today 2 speed f**k it hammers. so loud as well i recon we made a few people mad.
still recon my drifter is more fun :D rx7 shell ftw although i broke the front LED headlights tonight :(
When i start my car, my hicas light stays on. After driving off down the road, it will turn off. Needs to do hicas diagnosis check. Wonder what is triggering it.
1. try checking ur power steering fluid might need top up, iv heard that can cause it.
2. check the main hicas plug on the diff is not loose.
3.check the other wires and hicas pump.
very annoying good luck....:thumbsup:
how come?
Damaged the bits that hold the 2 leg bones together, and they were separating, so got a screw put in.
Surgeon told me I'm not allowed to drive or do anything for 2 weeks ffs, not sure how I'm supposed to go to uni....
I have a dilema: I effing <3 Skylines, but I buy a ute to carry the bikes and it's pretty sweet as well.
Only problem is, now that I own it, when I drive I look at Jap cars and feel sick with envy and want to buy one. But I still own one... >_<
Will I never be happy no matter how many cars I own? lol.
Welcome to my world.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
