im using the powerfc boost kit and it works well
when you use it you get boost print out on the hand controller and the powerfc will correct based on boost as well
set and forget and away you go
set target boost, set duty to reach that level and your done
it doesnt do dual solenoid or any fandangle stuff
so if your on std turbos etc its fine
if you want 3.6kgcm2 of boost with instant scramble then get a dual solenoid unit
Ok...
So a Power FC does a boost controller built in?
i wonder how your 34R would go with 4.11 diff gears
how do you find its acceleration at the moment with std diff gears scotty
well i dont have anything to really base it on but its definitely quick. for a 6 speed the gearings are very close together. i can be in 5th doing 60km/h and still have enough pick up to get to 100km/h quicker than alot of little cars. i find first gear to be very quick and 2nd gear is the fun gear because if im on fullboost in 3rd im going well over any speed limit.
that probably didnt answer your question lol. if you have any specific questions about it i can answer.
A question for wasteland, I have never changed the pannel filter in my gtr and was thinking about doing it this weekend, I have a sticker on the airbox saying nismo filter, I was wondering if there are any markings/branding on the filter itself to let me know that it is actually a nismo/k&n filter?
the powerfc has the logic and code built into the unit for the boost control kit
but you cant use it without the sensor, harness and solenoid
the menus are on the hand controller etc
the boost kit itself includes
an additional wiring harness
a map sensor
a boost solenoid
on the the side of the powerfc is a white socket, you plug the harness in there and plug in the map sensor and solenoid
so you dont have to do any wiring or splicing etc, just plug and pray
then set boost on the menu and duty and your done
the AVCR uses the same parts but has different controller logic
the avcr has boost scramble, boost gain etc and other features
but it uses the same sensor, harness, solenoid
you can mix and match them (the parts)
No. It's a seperate add on piece.
a map sensor
a boost solenoid
I see, cool thanks!
nah most agents drive bmws/lexus/merc/audi well the decent ones the average ones drive mazda's/honda's etc
i just need something suitable for towing and i dont see myself in a 4x4 could get a lexus gs430 4.3ltr v8 would probably do the job but not sold on teh look of em
i rkn ve's look tits.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
