Vic Wasteland Thread
paulr33
it's usually a % of the pay out value...ie if the repairs cost $x amount, and the value is $x amount, if the cost of repairs is more than xx% of the value of the car, they write it off
my brother knows a repairer who might be willing to pass it on as a write off. see how it goes
wow that sucks rimon.. hope it gets sorted
astro- fkn lol
grant, gun grey s3 R33 GTR http://cgi.ebay.com.au/1997-Nissan-Skyline-TURBO-V-SPEC-R3-GTR-V-SPEC-Grey-M-/390300486754?pt=AU_Cars&hash=item5adfb8cc62
that colour looks queer on 33R, its too gtst'ish
silver 33Rs on black rims looks best imo. i don't care much for that midnight purple either only looks decent on 34Rs
I herd you leik SLS AMG parked on Toorak road in No standing zone. Parking Fine and Red P-Plates O_o
Are you positively annoyed friend?
Yup. I are mad
Have 9 tyres/rims stacked ontop of each other, decided to pull down the wall of rims. Pulled off 5 rims and was confronted by a massive possum sleeping in between the rims. No idea how he managed to squeeze through each spoke of the rims to get down so far in the column of rims haha
Ive jabbed him with a stick but he aint waking up. Will wait for him to crawl out before i dismantle his house
    • Hi all,   I have been a member here for years and am back to owning an R35.  It's my car and thought members of the community might enjoy sharing my journey.  I am definitely here to join the conversation.  If sharing this content isn't appropriate or it belongs somewhere else, I am happy to have it deleted or moved...
    • Data looks rock solid? I'm assuming you jabbed the throttle twice OR once? the TPS voltage moves up and down twice, however you've mentioned you did it once.
    • Having not watched the videos, I'm unsure, but this may be better suited to the importing thread?
    • Update on this situation: (Forgot to put in my previous post that I bought another brand new pressure gauge and fuel shows the same 50psi) I've deleted all the aftermarket immobilizers and turbo timer shyt and placed all factory wiring back to normal. The problem is still the same and nothing changed, but atleast it's a bit more tidier under the steering wheel. I've also siphoned out all the old fuel and then poured new batch of BP98 fuel (about 15L) into the tank. Nothing changed. Still the same idle. I also changed out the MAP vac line with a new one and, still the same.  So 2 days ago, I thought fk it. I'll just change out the fuel rail and injectors with another set that I know worked well in my brother's R34 a while back. That other fuel rail has the exact same Xspurt 640cc as what I have right now. So I changed it out to that other fuel rail and injectors (new O-rings) and injector harness. Put everything back together, started the engine, 464906286_1624569924763105_5179888796065901094_n.mp4   and yeah... still the same 50psi and idle problem. 🫠 I can also hear each of injector's solenoids running when I put a screw driver to it and have the other end to my ear. I might get a noid light just to confirm pulsasion but yeah, very strange that both fuel rails and injectors put out 50psi.  31-10-2024.csv I've attached it here. I started recording, then started the engine and let it idle with no throttle, then at the end I applied a little throttle and then stopped recording.    So, now idk. I'm going to see if swapping out the brand new R35 coils to my old splits fires will change anything. 🤷‍♂️
    • Hey mate, nice work on the car. Just a quick note, people generally don't like it when you use the forums to dump and run to advertise your YouTube content. If you're gonna stick around and join in the conversation then great, but if not this might not be the best place for you.
